Using 2x74HC595 shift registers to control 4digit 7 segment display
Thank you so much johnwasser.I got the 4digit 7segment display with two shift registers module.you give me very excellent suggestion.now,i am going to try another code like below...
but.i still have another problem,that is how can i let the display always on.the code
ts2 += 5; // display-update interval = 5msec ,I don't know how to modify it...
#include <Four7Seg74hc595.h>
* press button to counter increment
esl::Four7Seg74hc595 display( 10,9,8 );
// Pin connected to Pin 14 of 74HC595 (Data=DIO,arduino pin8)
// Pin connected to Pin 12 of 74HC595 (Latch=RCLK,arduino pin9)
// Pin connected to Pin 11 of 74HC595 (Clock=SCLK,arduino pin10)
char sbuf[5];
uint16_t count;
uint32_t ts1, ts2;
const int buttonPin = 2;                 // (pushbutton)
const int relayPin = 13;                 // (Relay)
unsigned long detectingtime = 15000;
int buttonPushCounter = 0;   //counter for the number of button presses
int buttonState = 0;         //current state of the button
int lastButtonState = 0;     //previous state of the button
  Serial.begin(9600);                     // Serial port,  9600 bps
  pinMode(buttonPin, INPUT);             //buttonPin set to INPUT
  pinMode(relayPin, OUTPUT);             // relayPin set to OUTPUT
  for (uint8_t i=0; i < 100; i++) {
    display.setDigits( "----", 4 );
    display.update();
    delay(10);
  sprintf( sbuf, "%04u", buttonPushCounter );
  display.setDigits( sbuf, 4 );
  display.update();
  ts1 = ts2 = millis();
uint32_t ts;
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState) {
    // check button(pressed)
  // buttonState to HIGH
  if (buttonState == HIGH) {
        // if the current state is HIGH then the button
      // went from off to on:
      buttonPushCounter++;
      Serial.print("number of button pushesON:  ");
      Serial.println(buttonPushCounter,DEC);
      ts = millis();
      if ( ts - ts2 >= 5 ) {
      display.update();
      delay(15000);
      digitalWrite(relayPin, HIGH);
      digitalWrite(relayPin, LOW);
  else if (buttonState == LOW) {
       // if the current state is LOW then the button
      // went from on to off:
      Serial.print("number of button pushesOFF:  ");
      ts = millis();
      sprintf( sbuf, "%04u", DEC);
     display.update();
     delay(3000);
  lastButtonState = buttonState;  // save the current state as the last state, for next time through the loop
Update your post to use the [code ] tags. See How to use this forum
But uhh, is it just me... You use 74hc595 and the code is for 74hc595, what's the problem?
Two shift registers will get you 16 bits of output. That's not enough to control four 7-segent displays without multiplexing. It can be done but is too complex to write easily. Perhaps you can add three shift registers so you have one shift register per digit. That is much easier to control:
void displayNumber(int number) {
  digitalWrite(latchPin, LOW); // Set latchPin LOW while clocking these 8 bits in to the register
  shiftOut(dataPin, clockPin, MSBFIRST, numbers[(number / 1000) % 10]);
  shiftOut(dataPin, clockPin, MSBFIRST, numbers[(number / 100) % 10]);
  shiftOut(dataPin, clockPin, MSBFIRST, numbers[(number / 10) % 10]);
  shiftOut(dataPin, clockPin, MSBFIRST, numbers[number % 10]);
  digitalWrite(latchPin, HIGH); //set latchPin to high to lock and send data
