Hi.
I'm creating a play dashboard for my son, and have got my hands on an old 3 wire tachometer (Black, Red and Yellow).
From what I can figure out, these are +12V, GND and Signal, and the signal is coming from the Coil of the car it used to sit in.
What voltage would this need to respond, and could I use a simple square wave generator to run it?
gbremset:
Hi.
If it connected to the coil, it was the primary winding, so it was 12 volts, except when the ignition points opened the circuit to fire a spark plug. If you can get a square wave generator to generate 12 volt peak, then should work.
Paul
