Using 4*4 matrix keypad to control outputs
Hello all,
I am new to arduino and have a 4*4 matrix keypad and arduino Uno and a 5v 4 channel relay board. I am trying to control each relay channel with an "A","B","C","D" and I cannot figure out how to code it. I coded enough to make the keypad say the character I pressed in the serial monitor but how do I now change it to to control outputs? I have looked all over the internet and cannot figure it out. Any help would be appreciated!
Btw, the keypad is connected to PWM Pins 2-9 and I have the relays connected 10-13.
hit reply and post the code you have (before cutting and pasting code use crtl + t to format the code for easy reading)
Free snippet
switch ( Keypad.getKey() )
    case 'A':
      // do something with relay 1
    case 'B':
      // do something with relay 2
    case 'C':
      // do something with relay 3
    case 'D':
      // do something with relay 4
    default:
      // do something else
i prefer you using ShiftRegister it's easier
HazardsMind:
Free snippet
    case 'A':
case 'B':
case 'C':
case 'D':
    default:
Thank you HazardsMind very much! I have not been active, nor have I been online in a long time but thank you because I still want to finish that project!
