Using 4 buttons to switch between LED Matrix scenes
Hey! As stated in the title, I'm trying to make an LED wall that I can switch between different Glediator scenes, saved to an SD card, using 4 different buttons. I've got the electronics working without a hitch, but the programming is biting me in the arse! The below link is the code I've got thus far. The idea is that it loops through 'checkSensor' functions, and depending on the buttons state activates a scene from the 'triggerAnimation' array. I'm having a load of issues with it though and I'm not proficient enough at coding to know how to fix it :frowning:
These are the error codes I'm getting
AIMmatrix:230:15: error: expected constructor, destructor, or type conversion before ';' token
 checkSensor3();
AIMmatrix:231:1: error: expected unqualified-id before 'if'
 if (sensorState3 == LOW) {
exit status 1
Any help would be much appreciated!
checkSensor3();
See the problem now?
That code is outside your loop() function. You have your closing '}' in the wrong place.
This sort of thing really doesn't help
Try using the auto-format tool more often.
AWOL:
checkSensor3();
No I still don't :frowning: If I remove ; I just get
exit status 1
expected constructor, destructor, or type conversion before 'if'
blh64:
Thank you! I worked it out. The problem now is I don't have enough memory! Does anyone have advice on how I can shrink the code down at all? 4buttmatrix - Pastebin.com
use fewer LEDs or get a bigger board (mega)
