Using 5 URM37 Ultrasonic Sensors
I using 5 URM37 ultrasonic connect to Duemilanove, the use the TTL signal to generate the signal.
The connection is Trigger and Enable all same pin, PWM is 3,5,6,9 and 10. After i compile and upload and connect all the 5 sensors to the arduino Duemilanove card, not problem but i cannot get any reading of the signal.
May i know what wrong is it?
below is the 5 sensors
// Pins for ultra URM37 V3.2
int ultraData[] = {3,5,6,9,10};
int ultraTrigger = 11;
int ultraEnable = 12;
int ultraPower = 8;
int ledPin = 13; // LED connected to digital pin 13
 Serial.begin(9600);                  // Sets the baud rate to 9600
  pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
int ping(int ultraSoundSignal){    // this function returns the time for the sensor on the given pin
int val=0;
int ultraValue=0;
int timecount=0;
// Wake up and get ready for sensing
  pinMode(ultraPower, OUTPUT);
  digitalWrite(ultraPower, HIGH);  // Set to HIGH to provide 5V power
  pinMode(ultraEnable, OUTPUT);
  digitalWrite(ultraEnable, HIGH); // Set Enable Pin to HIGH
  pinMode(ultraTrigger, OUTPUT);   // Switch signalpin to output
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
  delay(200); //Give sensor some time to start up --Added By crystal  from Singapo, Thanks Crystal.
   /* Send high-low-high pulse to activate the trigger pulse of the sensor
  digitalWrite(ledPin,LOW);
  digitalWrite(ultraTrigger, HIGH); // Send High pulse
  delayMicroseconds(500);
  digitalWrite(ultraTrigger, LOW); // Send low pulse
  delayMicroseconds(200);
 /* Listening for echo pulse
do{
  val = digitalRead(ultraSoundSignal); // Append signal value to val
}while(val == HIGH); { // Loop until pin reads a high value
 do{
    timecount ++;
    delayMicroseconds(50);
}while(val == LOW);  // Loop until pin reads a high value
  ultraValue=timecount;
  //val = digitalRead(ultraSoundSignal);
             // Count echo pulse time
return  timecount ;
// Turn the lights out when you leave...
  digitalWrite(ultraTrigger,LOW);
  digitalWrite(ultraEnable,LOW);
  digitalWrite(ultraPower,LOW);
  int ultraValue;
  int i;
  for(i=0; i < 5; i++){
       ultraValue = ping(ultraData[i]);
      // Serial.write('A + i'); // Example identifier for the sensor
       Serial.println(ultraValue);
       Serial.write(10);
       Serial.write(13);
/* Delay of program
  delay(10);
Thanks
if your use 5 ultrasonic sensors, i think I2C bus will better than Uart. ultrasonic senser of KS101B may better.technical specification can ne seen in http://www.dauxi.com/KS10X-V110_EN.pdf
