Here is my code
int latchPin = 2; //pin 12 on the 595
int dataPin = 3; //pin 14 on the 595
int clockPin = 4; //pin 11 on the 595
int numHex[] = {63, 6, 91, 79, 102, 109, 125, 7, 127, 103};
int daerah[4][4] ={ // {latchPin, dataPin, clockPin, input}
{2, 3, 4, 2342}, // johor
{5, 6, 7, 4321},
{8, 9, 10, 7834},
{11, 12, 13, 4321},
{14, 15, 16, 7834},
{17, 18, 19, 4321},
{20, 21, 22, 7834},
{23, 24, 25, 4321},
{26, 27, 28, 7834},
{29, 30, 31, 7834},
{32, 33, 34, 394}
for (int i = 1; i < 14; i++){
pinMode(i, OUTPUT);
for( int i = 0; i < 4; i++){
display(daerah[i][0],daerah[i][1],daerah[i][2],daerah[i][3]);
void display(int latchPin, int dataPin, int clockPin, int num){
int num1=num/1000;
int num2=(num/100)-(num1*10);
int num3=(num/10)-(num1*100)-(num2*10);
int num4=num-(num1*1000)-(num2*100)-(num3*10);
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST,63);
shiftOut(dataPin, clockPin, MSBFIRST,numHex[num1]);
digitalWrite(latchPin, HIGH);
delay(1);
shiftOut(dataPin, clockPin, MSBFIRST,128 + 63 << 1);
shiftOut(dataPin, clockPin, MSBFIRST,128 + numHex[num2]);
delay(1);
shiftOut(dataPin, clockPin, MSBFIRST,128 + 63 >> 5);
shiftOut(dataPin, clockPin, MSBFIRST,128 + numHex[num3]);
delay(1);
shiftOut(dataPin, clockPin, MSBFIRST,128 + 63 >> 4);
shiftOut(dataPin, clockPin, MSBFIRST,128 + numHex[num4]);
delay(1);
The code is fine. its working.
But the problem is when i want to make the 12 unit (4 digit 7 segment).
The light start to dimm and some number doesn't appear. So i add 4 transistor(2n2222) for
each digit. the brightness is getting better. but the problem is its only display '2222' instead of '2342'.
