I am working on a PCB that has 2 ESP32-S3 on it and I was thinking of using a switch, together with 4 and-gates to redirect the signal to different microcontrollers. I found out, that the frequency of the usb-protocol is usually 12MHz but could also be more and I wanted to know if it is a good idea to use the 74hct08 IC or if there is another way for me to move the signals.
My implementation has one pin of the switch connected with D+ and D- on 2 gates, while the other pin is connected with them on 2 other gates. Both outputs of the switch are pulled down and the common pin is connected to 5V.
I could not find any help on this and the only idea that i had was to compare the period of the usb-protocol and the transition time of the IC. Anyone know if this would work? And if not, Should I use a Tri-State buffer instead?
My schematic is mixed up. I have split it into multiple sheets but the amount of elements on each sheet makes it hard to single out the circuit. I will upload pictures of the schematic from now on.
From what I can see in the datasheet of the TS3USB221DRCR, OE is just to enable if the data is sent further or not. Correct me if I'm wrong, but could I simply connect it to ground? I was also wondering how exactly the S pin works. I'm guessing the input is connected to 1D+ and 1D- when S is low and with 2D+ and 2D- when S is high.
Thank you for the recommendation. I have implemented the TS3USB221DRCR IC. However, I would still like to know how the S pin influences the output. If 1D+ and 1D- are connected to the output when S is 0 or 1.
Also to consider is the data rates are negotiated between TWO devices at startup. A second device will NOT know the current data rate between the PC and the first device. Also you will NOT want to switch while a message transmission is in progress!
Hello, That is not my intention. I use the switch to choose which microcontroller is connected to the USB connector. It will mostly communicate with only one of the 2 esp32, since the other is used as peripheral manager, so it will be programmed once with a bridging program, allowing the 1st esp32 to tell it which pins should be turned on and off.
