This a question about "OR" gates. The Arduino's work correctly.
I have 11 Arduino's linked together by a cable. I have not interfaced them directly but via "OR" gates. Each Arduino has one output and one input from its neighbour. The two way communication uses 3 wires, one common ground and the two others for the signal.
There is a common power supply, a legacy 24V, which is reduced to 12V and then 5V by 78xx devices at each location.
All work correctly except for 1 output.
Unconnected, the sending "OR" gate switches fine, 0.13V "off" and 4.25V "on" as controlled by the processor.
By using "jump leads" to connect to either ground or +5V, the input of the receiving "OR" gate also works fine and can be "read" by its processor.
However, connect the sending "OR" gate to the receiving "OR" gate by the cable, I then get a negative output from the sending "OR" gate, -1.5V, when "off".
The output going back the other way is okay. Its the same common ground!
The "on" voltage is then only +2V, which is not high enough to change the state of the receiving "OR" gate.
Can anyone explain and then help me solve this phenomenon?
Confused from the UK.
