Using 80mm thermal printer RS-232 for bmps
this old post 80mm Thermal Printing image with uno *SOLVED*
used GitHub - AndersV209/Pos-Printer-Library: Arduino Library for Thermal Printers
This is an Arduino library for a POS(point of sale) Printer. This library is testet on a samsung SRP-350G printer. These printers use TTL serial to communicate, 2 pins are required. But can have rs-232 or other cards in the back, that convert othersignals to ttl, so you might need a soldering iron to add 2-3 wires.
I'm using an Epson TM-T88III M129C Serial RS-232
Dont quite udnerstand what this description means - will this driver work for rs232?
the printer is on its way so want to get everything set up asap as working to very tight deadline
anyone had experience with 80mm with bmps?
Do you have the datasheet for your printer?
Can you provide a link to it?
