Hi everyone,
I'm currently working on my first project (an irrigation system) and since I'm running out of pins on my Uno R3, I got an I2C module for my LCD. It uses a PCF8574T chip (datasheet) and I just can't figure out how to use it.
First I soldered a female header strip to the 16 holes of the module and plugged my LCD in there. Both the I2C module and the LCD module were marked with "1" and "16" on both ends of the contacts and I made sure that these numbers were matching. I connected VCC and GND to +5V and ground and SCL/SDA to the respective pins on my Uno. I used 10K pull-up resistors for the SDA/SCL pins.
I found an alternative LiquidCrystal library that also supports I2C and there was a "hello world" example for I2C that I tried to get running. I changed the lcd address in the example and the only one that worked at all was "0x20". But it doesn't show "hello world", it only shows random blinking cursors in different places.
Can anyone help me out? I think I've come pretty far all by myself but now I'm a bit lost. I don't have a programming or electronics background, so many things aren't as self-explaining to me as they may be for some of you guys.
Thanks a lot in advance! Please let me know if I left out any important info.
