Using a 1x4 Keypad to switch between loops
Hi Community,
I have a project that I am creating with a ardunio uno microcontroller. I am using to to examples on the ardunio website: one sketch uses a potentiometer to vary a LED, the second sketch uses sin function to vary the LED. I combined both of these sketches with the use keypad to switch between the loops. The main sketch works; however when I press the button to switch to the sin function, I can't get it out of the loop to go back to the other loop. Could I get some advice on my sketch.
#include <Key.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 1; //one columns
char keys[ROWS][COLS] = {
	{'1'},
	{'2'},
	{'3'},
	{'4'}
byte rowPins[ROWS] = {7, 6, 5, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//byte ledPin = 3;
const int Poten = A0;  // Analog input pin that the potentiometer is attached to
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  3;      // the number of the LED pin
void setup(){
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(ledPin, HIGH);   // sets the LED on
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  char key = keypad.getKey();
  if (key) {
    Serial.print("Pressed: ");
    Serial.println(key);
//take care of some special events
void keypadEvent(KeypadEvent key){
  switch (keypad.getState()){
    case PRESSED:
      switch (key){
        case '1': loop2(); break;
        case '2': loop1(); break;
  void loop1(){
     int key1 = keypad.getKey ();
    while(1){
        if (key1)
        {break;} // leave the loop
        int value = analogRead(Poten);
        int led_speed = value/4;
        analogWrite(ledPin, led_speed);
        Serial.println(led_speed);
        delay(1);
void loop2(){
   while(1){
      if (key1)
   for(int i = 0; i<360; i++){
    //convert 0-360 angle to radian (needed for sin function)
    float rad = DEG_TO_RAD * i;
   //calculate sin of angle as number between 0 and 255
    int sinOut = constrain((sin(rad) * 128) + 128, 0, 255);
    analogWrite(ledPin, sinOut);
    delay(15);
    Serial.println(sinOut);
(code tags added by moderator)
Quick reply off the top of my head on lunch:
The loop() function will always be called, and without writing your own code from scratch cannot be stopped - short of stopping the whole program.
What you want is a basic state machine - there's a few examples around on how to implement one, but the basic idea would be something like this (along with your setup stuff):
enum Tasks
    Task1
    Task2
    Task3
} currentTask;
void doTask1()
    Serial.println("Doing Task 1");
void doTask2()
void doTask3()
		case PRESSED:
		switch (key)
			case '1': currentTask = Task1; break;
			case '2': currentTask = Task2; break;
			case '3': currentTask = Task3; break;
  if(currentTask == Task1)
	doTask1();
  else if(currentTask == Task2)
	doTask2();
  else if(currentTask == Task3)
	doTask3();
That's the basic idea - the code might not work as a drop in but I hope it helps.
Also you might want to place your code into code tags (the # button) :wink:
