I've had a frustrating night,
I picked up a few NTE4051B's
I used this guide:
http://www.arduino.cc/playground/Learning/4051
And the help of "Cheater" in the forums to get everything squared away.
The pots I'm using are 1 Meg Ohm.
And here's my code:
int led = 13;
int r0 = 0; //value select pin at the 4051 (s0)
int r1 = 0; //value select pin at the 4051 (s1)
int r2 = 0; //value select pin at the 4051 (s2)
int row = 0; // storeing the bin code
int count = 0;
int bin [] = {000, 1, 10};
void setup(){
pinMode(2, OUTPUT); // s0
pinMode(3, OUTPUT); // s1
pinMode(4, OUTPUT); // s2
beginSerial(9600);
void loop () {
for (count=0; count<=2; count++) {
digitalWrite(led, HIGH);
row = bin[count];
r0 = row & 0x01;
r1 = (row>>1) & 0x01;
r2 = (row>>2) & 0x01;
digitalWrite(2, r0);
digitalWrite(3, r1);
digitalWrite(4, r2);
Serial.print(analogRead(1));Serial.print(" ");
delay(100);
digitalWrite(led, LOW);
delay(100);
Serial.println("");
Alright, enough set-up. I'm not really getting the desired input, just a bunch of random numbers
I also tried adding all 6 ports to the bin array to see if I had those wrong.
Do I have anything wrong? The 1401's top is on the left. The only thing I've noticed is the 1401 gets scorching hot. Kinda got me worried.
I'd appreciate any help anybody has!
