My data collection project requires a Teensy 3.6 with the keypad as an I2C module. I've used a slightly modified version of Steve Stover's code. This is the most reliable method I've found for using this keypad. It works fine with a Uno, but gives an expected constructor, destructor, or type conversion before '(' token error when compiling for the Teensy.
My C coding skills are not up to sorting this out, so any advice/help with be appreciated:
touchpad16_interrupt.ino
Created: 5/27/2015 9:02:08 PM
Author: Steve Stover
16 Key Capacitive Touchpad using TTP229B IC
http://www.ebay.com/itm/371304274498
The Touchpad has a jumper on TP1/SAHL for active high serial out
and a jumper on TP2/KYSEL for 16-keys operation
Processing the input via external interrupt INT1
on an Arduino Nano v3.0
https://forum.arduino.cc/index.php?topic=301382.0
#include <util/atomic.h>
#define CLR(x,y) (x&=(~(1<<y)))
#define SET(x,y) (x|=(1<<y))
#define clock_Pin 2
#define sdo_Pin 3
#define beep_Pin 8
// Touchpad value
volatile uint16_t touchVal; // var for ISR access
uint16_t touchValc; // copy var for main loop
const int NUMBER_OF_ELEMENTS = 16;
const int MAX_SIZE = 14;
char desc [NUMBER_OF_ELEMENTS] [MAX_SIZE] = {
{ "D:short pause" },
{ "D:long pause" },
{ "D:converse" },
{ "D:sniff" },
{ "D:en passant" },
{ "D:functional" },
{ "D:greet" },
{ "D:tug" },
{ "D:investigate" },
{ "D:roll" },
{ "D:wait" },
{ "P:converse" },
{ "P:tug" },
{ "P:wait" },
{ "P:view" },
{ "P:functional" },
pinMode(clock_Pin, OUTPUT);
pinMode(sdo_Pin, INPUT);
pinMode(8, OUTPUT);
beep(200);
beep(50);
beep(50);
// set up INT1 on digital pin 3
EICRA = (1 << ISC11) | (1 << ISC10); // external INT1 on rising edge
EIMSK = (1 << INT1); // External Interrupt Request 1 Enable
sei();
ATOMIC_BLOCK(ATOMIC_FORCEON) {
touchValc = touchVal;
if (touchValc) {
// Serial.print(touchValc, DEC);
for (byte b = 0; b <= 15; b++) {
if ((touchValc >> b) & 1) {
// Serial.print('\t'); Serial.print("bit "); Serial.print(b);
// Serial.print('\t'); Serial.print("pad "); Serial.print(b+1);
switch (b) {
case 0 :
Serial.println(desc[0]);
case 1 :
Serial.println(desc[1]);
case 2 :
Serial.println(desc[2]);
case 3 :
Serial.println(desc[3]);
case 4 :
Serial.println(desc[4]);
case 5 :
Serial.println(desc[5]);
case 6 :
Serial.println(desc[6]);
case 7 :
Serial.println(desc[7]);
case 8 :
Serial.println(desc[8]);
case 9 :
Serial.println(desc[9]);
case 10 :
Serial.println(desc[10]);
case 11 :
Serial.println(desc[11]);
case 12 :
Serial.println(desc[12]);
case 13 :
Serial.println(desc[13]);
case 14 :
Serial.println(desc[14]);
case 15 :
Serial.println(desc[15]);
beep(20);
void beep(unsigned char delayms) {
analogWrite(9, 200); // Almost any value can be used except 0 and 255
// experiment to get the best tone
delay(delayms); // wait for a delayms ms
analogWrite(9, 0); // 0 turns it off
ISR(INT1_vect) {
touchVal = 0;
delayMicroseconds(100);
for (byte i = 0; i <= 15; i++) {
SET(PORTD, clock_Pin);
delayMicroseconds(50);
touchVal |= (digitalRead(sdo_Pin) << i);
CLR(PORTD, clock_Pin);
The error messages are:
Arduino: 1.8.8 (Mac OS X), TD: 1.45, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
keypad_03:145: error: expected constructor, destructor, or type conversion before '(' token
ISR(INT1_vect) {
keypad_03: In function 'void setup()':
keypad_03:66: error: 'EICRA' was not declared in this scope
keypad_03:66: error: 'ISC11' was not declared in this scope
keypad_03:66: error: 'ISC10' was not declared in this scope
keypad_03:67: error: 'INT1' was not declared in this scope
/Users/david/Arduino/keypad_03/keypad_03.ino: At global scope:
ISR(INT1_vect) {
Many thanks
