Using a bluetooth module to send/receive more than 1 information
Hey guys,
I recently bought a Bluetooth module ( HC-05) to use it in a personal project but I'm wondering if we can send/receive multiple informations. I use MIT app inventor to create my app and send my data to the Bluetooth module. I also plug the Tx and Rx pins of the HC-05 to the pins Rx and Tx of my Arduino.
So can we to that or the limit is one information.
Thank you for your help.
Steewz
What have you tried?
Is “<12,34,56>” one information, or more than one?
This is my code here the goal was to turn on a led depending on which information ( 1 2 or 3 ) I send from my phone to the BT module.
I tried to control with a slider on my app the brightness of my led ( from 0 to 255 ), and there is the problem if the slider reaches the values 0 1 or 3 it will activate the other instructions, that's why I'm asking if there is a way to send two different information, so can we for example set two variables that read the serial at the same time, one for numbers(int) and the other for a text for example(char) or there is another way to do it.
int state = 0;
const int ledr = 8 ;
const int ledb = 9 ;
const int ledg = 10 ;
pinMode(ledr, OUTPUT);
pinMode(ledb, OUTPUT);
pinMode(ledg, OUTPUT);
if(Serial.available() > 0){
state = Serial.read();
if (state == '0') {
digitalWrite(ledr, LOW);
digitalWrite(ledb, LOW);
digitalWrite(ledg, LOW);
Serial.println("LED: OFF");
state = 0;
delay(1000);}
if (state == '1') {
digitalWrite(ledr, HIGH);
Serial.println("Red Led: ON");
if (state == '2') {
digitalWrite(ledb, HIGH);
Serial.println("Blue Led: ON");
if (state == '3') {
digitalWrite(ledg, HIGH);
Serial.println("Green Led: ON");
Steewz:
Yes.
Can you please give me an example
Serial input basics - I think example 5 has everything you need but read the rest as well.
Steve
Yes, I can give you an example. Here are 3 tasks that ae sending different data sets meant for different destinations over the same serial port.
void fLIDAR_Is_OK ( void *pvParameters )
  String sSerial = "<$>";
  TickType_t xLastWakeTime;
  const TickType_t xFrequency = pdMS_TO_TICKS( 1000 );
  xLastWakeTime = xTaskGetTickCount();
  for ( ;; )
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    bool LIDAR_OK = true;
    if ( xSemaphoreTake( sema_SendSerialToBrain, xZeroTicksToWait ) == pdTRUE )
      if (xHANDLE_LIDAR_ServoAspectChange == NULL )
        Serial.println ( " xHANDLE_LIDAR_ServoAspectChange " );
        LIDAR_OK = false;
      if ( xHANDLE_DoLIDAR == NULL )
        Serial.println ( " xHANDLE_DoLIDAR " );
        LIDAR_OK = false;
      if ( xHANDLE_SendLIDAR_InfoSerialToBrain == NULL )
        Serial.println ( " xHANDLE_SendLIDAR_InfoSerialToBrain " );
        LIDAR_OK = false;
      if ( xHANDLE_SendSerialToBrain == NULL )
        Serial.println ( " xHANDLE_SendSerialToBrain " );
        LIDAR_OK = false;
      if ( xHANDLE_TweakServoX == NULL )
        Serial.println ( " xHANDLE_TweakServoX " );
        LIDAR_OK = false;
      if ( xHANDLE_TweakServoY == NULL )
        Serial.println ( " xHANDLE_TweakServoY " );
        LIDAR_OK = false;
      if ( xHANDLE_GetIMU == NULL )
        Serial.println ( " xHANDLE_GetIMU " );
        LIDAR_OK = false;
      if ( LIDAR_OK )
        SerialBrain.println ( sSerial );
    xSemaphoreGive ( sema_SendSerialToBrain );
  vTaskDelete( NULL );
void fSendLIDAR_InfoSerialToBrain( void *pvParameters )
  struct stu_LIDAR_INFO pxLIDAR_INFO;
  for ( ;; )
    xEventGroupWaitBits (eg, evtGetIMU, pdTRUE, pdTRUE, portMAX_DELAY);
    xSemaphoreTake( sema_LIDAR_FOR_ALARM, xSemaphoreTicksToWait );
    xQueueReceive ( xQ_LIDAR_FOR_ALARM, &pxLIDAR_INFO, QueueReceiveDelayTime );
    xSemaphoreGive( sema_LIDAR_FOR_ALARM );
    int CellCount = 1 ;
    String sSerial = "";
    sSerial.reserve ( 300 );
    sSerial.concat( "<#," );
    sSerial.concat( String(ScanPoints) + "," );
    sSerial.concat( String(pxLIDAR_INFO.ServoSweepUp) + "," );
    for ( CellCount; CellCount <= ScanPoints; CellCount++ )
      sSerial.concat( String(pxLIDAR_INFO.Range[CellCount]) + "," );
    sSerial.concat( ">" );
    vTaskDelay( 10 );
} // void fSendLIDAAR_InfoSerialToBrain( void *pvParameters )
void fSendSerialToBrain( void *pvParameters )
  for (;;)
    xEventGroupWaitBits (eg, evtSendSerialToBrain, pdTRUE, pdTRUE, portMAX_DELAY);
      int CellCount = 1;
      xSemaphoreTake( sema_LIDAR_INFO, xSemaphoreTicksToWait );
      xQueueReceive ( xQ_LIDAR_INFO, &pxLIDAR_INFO, QueueReceiveDelayTime );
      xSemaphoreGive( sema_LIDAR_INFO );
      sSerial.concat( "<!," );
} // void fSendSerialToBrain( void *pvParameters )
