using a button to complete two tasks
Hello, I was trying design a trap door with a limit switch, solenoid, servo, and button. I am trying to code a button to turn on a solenoid using a relay button and at the same time will turn on the servo to turn 90 degrees to close the trap door again. I am able to code turning on the solenoid by itself and the servo by its self But I am not sure how to integrate this together into the button. Any help would be greatly appreciated
my code is below
#include <Servo.h>
Servo myservo;
// constants
const int Switch = 2; // the number of the Switch pin
const int Sol = 4; // the number of the Sol pin
const int button = 3; // the number of the button pin
int pos = 0; // variable to store the servo position
// variables changing
int switchState = 0; // variable for reading the switch status
int state; // the current state of the Sol
int buttonState; // the current reading from the input pin
void setup(){
// inputs
myservo.attach(5); // attaches the servo on pin 9 to the servo object
pinMode(pos, OUTPUT);
digitalWrite (button, INPUT_PULLUP);
pinMode(button, INPUT_PULLUP); // button
pinMode(Switch, INPUT_PULLUP); // limit switch
// outputs
pinMode(Sol, OUTPUT); // solenoid
void loop(){
// reading state of both the button and the switch
switchState = digitalRead(Switch);
buttonState = digitalRead(button);
// loop for turning on/off solenoid
if (buttonState == HIGH && switchState == HIGH) // if limit switch is pressed down even though we press the button solenoid will not turn on
state = LOW;
else if (buttonState == LOW && switchState == LOW)
state = HIGH;
digitalWrite(Sol, state);
if (digitalRead(button) == LOW)
for(pos = 0; pos < 90; pos += 90) // goes from 0 degrees to 90 degrees
{ // in steps of degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
// waits 1s for the servo to reach the position
if (digitalRead(button) == HIGH)
for(pos = 90; pos>=90; pos-=90) // goes from 90 degrees to 0 degrees
delay(50); // waits 50ms for the servo to reach the position
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Please include power supplies and pin names, please not a fritzy image.
Thanks… Tom… :slight_smile:
