OK, got it in, but it isn't really working. The first button press works, but then it wants to play the animation and not detect the button presses. I tried to do an interrupt for the button, but to no avail. What am I doing wrong here? Sorry, the code is so messy, I've tried about 100 things:
#include <LEDPixels.h>
////Example to control RGB LED Modules with Spectrum Analyzer
//Bliptronics.com
//Ben Moyes 2010
//Use this as you wish, but please give credit, or at least buy some of my LEDs!
LEDPixels LP; //LEDPixels library
//For spectrum analyzer shield, these three pins are used.
//You can move pinds 4 and 5, but you must cut the trace on the shield and re-route from the 2 jumpers.
int spectrumReset = 5;
int spectrumStrobe = 4;
int spectrumAnalog = 0; //0 for left channel, 1 for right.
const int spectrumPower = 10; //pin used to power the spectrum analyzer on/off
const int buttonPower = 7; //pin used to power the button on/off
const int buttonPin = 6; //button read pin
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
//This holds the 15 bit RGB values for each LED.
//You'll need one for each LED, we're using 25 LEDs here.
//Note you've only got limited memory, so you can only control
//Several hundred LEDs on a normal arduino. Double that on a Duemilanove.
const int ledCount = 92;
int MyDisplay[ledCount];
byte bgColor[] = {0, 0, 31};
const int gridWidth = 23;
const int gridHeight = 4;
const int updateDelay = 30;
// Spectrum analyzer read values will be kept here.
int Spectrum[1];
int xx;
int yy;
attachInterrupt(1, increment, RISING);
/*___ Power ___*/
pinMode(spectrumPower, OUTPUT); //Makes spectrum shield power an output pin
digitalWrite(spectrumPower, HIGH); //Turns the spectrum shield on
pinMode(buttonPower, OUTPUT); //Makes button power an output pin
digitalWrite(buttonPower, HIGH); //Brings power to the button
/*___ Button Setup ___*/
pinMode(buttonPin, INPUT); //Reads the power from the button
/*___ LED Setup ___*/
byte Counter;
//Initialize the LEDPixels library.
// (refresh delay, address of data, number of LEDs, clock pin, data pin)
LP.initialize(25, &MyDisplay[0], 92, 9, 8);
// Setup the grid in the LEDPixels library to the setFastxxx calls work
LP.gridWidth = gridWidth;
LP.gridHeight = gridHeight;
//Setup pins to drive the spectrum analyzer.
pinMode(spectrumReset, OUTPUT);
pinMode(spectrumStrobe, OUTPUT);
//Init spectrum analyzer
digitalWrite(spectrumStrobe,LOW);
delay(1);
digitalWrite(spectrumReset,HIGH);
delay(1);
digitalWrite(spectrumStrobe,HIGH);
delay(1);
delay(1);
digitalWrite(spectrumReset,LOW);
delay(5);
// Reading the analyzer now will read the lowest frequency.
// Turn all LEDs off.
LP.setRange(0,91,LP.color(0,0,0));
LP.show(); //Write out display to LEDs
/*___ Button Loop ___*/
buttonCall();
/*___ Button Case Loop ___*/
switch (buttonPushCounter) {
case 0:
LP.setRange(0,91,LP.color(0,0,31));
LP.show();
showSpectrum();
case 1:
makeBlack();
case 2: //Color Wipes Animation
makeBlack();
MoveLines(LP.color(random(0,31),random(0,31),random(0,31)));
case 3: //Fading Animation
makeBlack();
for(xx=0;xx<32;xx++) { //Fade up from color
LP.setRange(0,91,LP.color(xx,xx,xx));
LP.show();
delay(30);
for(xx=31;xx>0;xx--) { //Fade down from color
LP.show();
delay(30);
case 4:
makeBlack();
for(xx=0;xx<23;xx++) {
LP.setPixel(0,xx,LP.color(0,31,0));
LP.setPixel(1,4-xx,LP.color(0,0,31));
LP.setPixel(2,xx,LP.color(0,31,0));
LP.setPixel(3,4-xx,LP.color(0,0,31));
LP.setPixel(4,xx,LP.color(0,31,0));
LP.show();
delay(200);
delay(updateDelay);
void increment() {
buttonPushCounter++;
if (buttonPushCounter == 5) { //Reset the counter when it exceeds a certain number
void buttonCall(){
buttonState = digitalRead(buttonPin);
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
while (buttonState == HIGH) {
// if the current state is HIGH then the button
// went from off to on:
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
// Read 7 band equalizer.
void readSpectrum() {
// Band 0 = Lowest Frequencies.
byte Band;
for(Band=0;Band < 1; Band++) {
Spectrum[Band] = (analogRead(spectrumAnalog) + analogRead(spectrumAnalog) ) >>1; //Read twice and take the average by dividing by 2
void showSpectrum() {
//No I don't use any floating point numbers - all integers to keep it zippy.
readSpectrum();
byte Band, BarSize, MaxLevel;
static unsigned int Divisor = 80, ChangeTimer=0, PullTimer = 0; //, ReminderDivisor,
static boolean Idle = false;
unsigned int works, Remainder;
MaxLevel = 0;
Idle = Divisor < 23;
for(Band=0;Band<4;Band++)//We only graph the lowest 5 bands here, there is 2 more unused!
//If value is 0, we don't show anything on graph
works = Spectrum[Band]/Divisor; //Bands are read in as 10 bit values. Scale them down to be 0 - 5
if(works > MaxLevel) { //Check if this value is the largest so far.
MaxLevel = works;
for(BarSize=1;BarSize <=23; BarSize++)
if( works > BarSize) {
LP.setLEDFast(LP.Translate(Band,BarSize-1), 0, 31, 0);
else {
LP.setLEDFast(LP.Translate(Band,BarSize-1), 31, 0, 0);
LP.show();
// Adjust the Divisor if levels are too high/low.
// If below 4 happens 20 times, then very slowly turn up.
if (MaxLevel >= 23)
Divisor=Divisor+1;
ChangeTimer=0;
PullTimer=0;
else if(MaxLevel < 22)
if(Divisor > 0)
if(ChangeTimer++ > 10 || PullTimer > 10)
Divisor--;
ChangeTimer = 0;
PullTimer++;
if(PullTimer > 15) {
Divisor--;
ChangeTimer=0;
//Set all LEDS and wait 1 second.
void All(unsigned int color) {
LP.setRange(0,91,color);
LP.show();
void MoveLines(int yy) {
//Draws 5 vertical lines in the requested color.
//Then follow them with 5 black lines for a wipe effect.
LP.line(0,xx,4,xx,yy );
LP.show();
delay(50);
LP.line(0,xx,4,xx,0 );
LP.show();
delay(50);
void makeBlack() { // Set LEDs to black.
LP.show(); //Send out data to LEDs.
