hi,
i have a course project where i decided to use nfc tags and readers to start a program on a computer.
because i havent coded much nor know an arduino very well i decided to try using a button 1st to start the program.
after some googl'ing i came onto inbetwino to use a path to start.
but every time i upload the code and start inbetwino, it just starts to program without interaction. and (when i placed it into loop instead of setup, it kept running it.)
(picture of board):
imgur picture link
code:
// First we'll set up constants for the pin numbers.
// This will make it easier to follow the code below.const int button1Pin = 7; // pushbutton 1 pin
int buttonState = 0;void setup()
// start serial
Serial.begin(9600);// Set up the pushbutton pins to be an input:
pinMode(button1Pin, INPUT);
buttonState = digitalRead(7);if (buttonState == HIGH);{
Serial.print("#S|RUNPROG|[]#");}
}void loop()
can anyone help me with this problem, and i will have to rewrite a bit later when the nfc tags arrive. but i rater like having a working button for now.
