Hi, everyone.
I'm putting together a scale project, where the load cell is far from the weight meter. With this, I convert the cell's analog signal and send it via WiFi to an ESP32 with a CJMCU-1334 module.
However, when converting the digital signal to analogue, I have difficulties.
At output p2 of the CJMCU-1334 module, the value read does not change when I change the digital value.
Can anyone help me?
Here's the code:
#include <Arduino.h>
#include <driver/i2s.h>
#include <WiFi.h>
const char* ssid = "ESP32_AP";
const char* password = "12345678";
const uint16_t port = 80;
const char* host = "192.168.4.1"; // Endereço IP padrão para o modo AP do ESP32
unsigned long lastTime = 0;
unsigned long interval = 100;
WiFiClient client;
// Configuração do barramento I2S
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = 44100, // Taxa de amostragem (ajuste conforme necessário)
.bits_per_sample = I2S_BITS_PER_SAMPLE_24BIT,
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false,
//.tx_desc_auto_clear = true,
// .fixed_mclk = 0
i2s_pin_config_t pin_config = {
.bck_io_num = 18, // Pino de clock de sincronização (Serial Clock)
.ws_io_num = 5, // Pino de seleção de palavra (Word Select)
.data_out_num = 4, // Pino de dados seriais (Serial Data)
.data_in_num = I2S_PIN_NO_CHANGE // Pino do sinal de dados de entrada (não usado neste caso)
i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
i2s_set_pin(I2S_NUM_0, &pin_config);
// Configuração Serial e WiFi
Serial.print("Conectando a ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi conectado.");
Serial.println("Endereço IP: ");
// Função para enviar dados digitais para o CJMCU-1334
void send_data_to_dac(uint32_t data) {
data = data & 0xFFFFFF; // Mantém apenas os 24 bits inferiores
size_t bytes_written;
i2s_write(I2S_NUM_0, &data, sizeof(data), &bytes_written, portMAX_DELAY);
if (!client.connected()) {
Serial.println("Conexão perdida. Tentando reconectar...");
if (!client.connect(host, port)) {
Serial.println("Conexão falhou.");
delay(5000);
return;
Serial.println("Reconectado ao servidor");
Serial.println("Conectado ao servidor");
while(client.available()){
String line = client.readStringUntil('\n'); // Lê até a quebra de linha
float valorCelulaCarga = line.toFloat(); // Converte para float
uint32_t sample = (uint32_t)valorCelulaCarga;
uint32_t dif = (uint32_t)valorCelulaCarga - sample;
Serial.println("Valor da célula de carga recebido: " + String(valorCelulaCarga, 4)); // Exibe com 4 casas decimais
Serial.println("uint32_t " + String(sample)); // Exibe com 4 casas decimais
Serial.println("Diferença " + String(dif)); // Exibe com 4 casas decimais
if (millis() - lastTime >= interval) {
lastTime = millis();
// Envie o valor digital para o CJMCU-1334
send_data_to_dac(sample);
delay(10);
