Using a Continuous Rotation Servo to move in small steps.
Hello Everyone,
I am trying to use a continuous rotation servo to turn a small knob. I need to turn the knob from 0 - 270 deg, slowly over about 10 min time. My programing skills are more or less non existent, so simple is better. Should I just get a regular servo and live with the range of 0 -180 deg?
Thanks,
-Spatsy
What is wrong with using your continuous servo?
(but pre-empting the regular solution perhaps FYI you should know that many regular servos will operate a little (and sometimes a lot) beyond their 180deg range...)
Im not able to get the servo to turn 1 deg and stop for say 10 sec.
Spatsy:
That's because it's not really a servo, rather it's an electric motor whose speed and direction is controlled by a PWM signal. My advice would be to use a regular servo or a stepper motor.
Thanks Heli,
So to code it with a reg servo I would just say: pos 0 delay 10000ms pos 1 delay 10000ms and so on untill 180?
Spatsy:
Yes.
However the Arduino can't do anything else during the delay() period whereas if you use millis() to manage timing it can do other things. See several things at a time.
And a sail-winch servo can do about 3 full revolutions with position control.
...R
Thank you all for you help and quick response. I went with a traditional servo and made my life a lot easier. Thanks again!
