Hello all, I am very new and have just been unable to find exactly what I need to make my Arduino Uno board pins activate with the arrows from my xbox controller. I am using the HAT sketch where it activates the lights on the drawing on my screen. I have the controller working and activating the lights. Now the problem comes when I try to make the arrows also turn on and off pins on my board. Specifically pins 8,9,10 and 11. Bellow I have included the current code I am running in processing. Any help would be very appreciated!
import cc.arduino.*;
import org.firmata.*;
import processing.serial.*;
Demonstrates how to get the input from a 'hat' control.
The hat switch is a simple digital joystick with 4 switches,
up, down, left and right. This sketch demonstrates how you
might get the hat inputs. You will need to create your own
configuration file.
for Processing V3
(c) 2020 Peter Lager
import net.java.games.input.*;
import org.gamecontrolplus.*;
import org.gamecontrolplus.gui.*;
ControlIO control;
Configuration config;
ControlDevice device;
ControlHat hat;
Arduino arduino;
// Variables to hold hat inputs
boolean hat_left, hat_right, hat_up, hat_down;
float hat_x, hat_y;
// Variables for hat drawing only
float hx = 90, hy = 90;
float hrad = 70, hbrad = 0.7*hrad, hbsize= 0.15 *hrad;
// Mikes added variables
boolean hat_leftstate=false;
boolean hat_rightstate=false;
boolean hat_upstate=false;
boolean hat_downstate=false;
size(200, 280);
surface.setTitle("GCP Cooliehat example");
arduino = new Arduino(this, Arduino.list()[0], 57600);
// Initialise the ControlIO
control = ControlIO.getInstance(this);
// Find a device that matches the configuration file
device = control.getMatchedDevice("hat-config");
if (device == null) {
println("No suitable device configured");
System.exit(-1); // End the program NOW!
hat = device.getHat("HAT");
textSize(16);
for (int i = 8; i <= 11; i++)
arduino.pinMode(i, Arduino.OUTPUT);
//set pins to outputs
void draw() {
getUserInput();
background(220);
// Hat face
stroke(40, 40, 200);
strokeWeight(1.5);
fill(200, 200, 250);
ellipse(hx, hy, 2*hrad, 2*hrad);
// Hat direction buttons
stroke(0);
strokeWeight(0.9);
fill(button_color(hat_left));
ellipse(hx - hbrad, hy, hbsize * 2, hbsize * 2);
fill(button_color(hat_right));
ellipse(hx + hbrad, hy, hbsize * 2, hbsize * 2);
fill(button_color(hat_up));
ellipse(hx, hy - hbrad, hbsize * 2, hbsize * 2);
fill(button_color(hat_down));
ellipse(hx, hy + hbrad, hbsize * 2, hbsize * 2);
// Hat direction values
fill(0);
text("X: " + hat_x, 20, 200, 200, 20);
text("Y: " + hat_y, 20, 230, 200, 20);
int button_color(boolean pressed) {
return pressed ? 0xffee2222 : 0xff771111;
// Poll for user input called from the draw() method.
public void getUserInput() {
hat_left = hat.left();
hat_right = hat.right();
hat_up = hat.up();
hat_down = hat.down();
hat_x = hat.getX();
hat_y = hat.getY();
