I have a Mini 04 that is soldered into a project.
http://www.arduino.cc/en/Main/ArduinoBoardMini -
I have a FTDI-cable with cabling like 4.1 in
http://www.ftdichip.com/Documents/DataSheets/Modules/DS_TTL-232R_CABLES_V201.pdf -
Now I want to solder a 6-pin header so I can connect this cable.
QUESTION 1: Am I wrong in supposing that this cable works?
As I understand, I just have to connect
a. GND (header pin for black cable) ==> GROUND on the Mini
b. VCC (header pin for red cable) => 5V+ on the Mini
And then just TXD + RXD.
QUESTION #2:
Do I connect the header pin for the orange cable (says TXD in FTDI datasheet) to the TX pin of the mini OR to the RX pin of the Mini?
No, I don’t want to trial and error.
QUESTION #3.
Can “all” other header pins (for cable CTS# and RTS#) just be left unconnected?
Regards/Hugs/Kisses/etc.
Madeleine
