Using a GSM shield with LCD03, Serial communication errors I believe
Hey guys i am doing a gas alarm system incorporating a Sim900a gsm module, an mq6 sensor and an LCD03. What it should do is, when subjected to a LPG send an sms to a mobile phone.
When i add the commands for the LCD03, the project stops working. I am wondering if it is because i am using serial communication to use the ports 9 and 10 for Rx,Tx to my GSM shield. And the LCD03 is connected to SDA and SCL which are also Tx and Rx. Would that cause the shield to stop sending the message?
Even if the lcd is not connected this problem persists.
#include <SoftwareSerial.h>
#include <Wire.h>
#include <LCD03.h>
SoftwareSerial mySerial(9, 10);
int sensor=7;
int speaker=8;
int gas_value,Gas_alert_val, Gas_shut_val;
int Gas_Leak_Status;
int sms_count=0;
pinMode(sensor,INPUT);
pinMode(speaker,OUTPUT);
mySerial.begin(9600);
lcd.begin(20, 4);
 lcd.backlight();
CheckGas();
CheckShutDown();
void CheckGas()
lcd.setCursor(0,0);
lcd.print("Gas Scan - ON");
Gas_alert_val=ScanGasLevel();
if(Gas_alert_val==LOW)
 SetAlert(); // Function to send SMS Alerts
int ScanGasLevel()
gas_value=digitalRead(sensor); // reads the sensor output (Vout of LM35)
return gas_value; // returns temperature value in degree celsius
void SetAlert()
digitalWrite(speaker,HIGH);
while(sms_count<3) //Number of SMS Alerts to be sent
SendTextMessage(); // Function to send AT Commands to GSM module
Gas_Leak_Status=1;
lcd.setCursor(0,1);
lcd.print("Gas Alert! SMS Sent!");
void CheckShutDown()
if(Gas_Leak_Status==1)
Gas_shut_val=ScanGasLevel();
if(Gas_shut_val==HIGH)
lcd.setCursor(0,1);
lcd.print("No Gas Leaking");
digitalWrite(speaker,LOW);
sms_count=0;
Gas_Leak_Status=0;
void SendTextMessage()
  mySerial.println("AT+CMGF=1");    //To send SMS in Text Mode
  mySerial.println("AT+CMGS=\"+919495xxxxxx\"\r"); // change to the phone number you using
  mySerial.println("Gas Leaking!");//the content of the message
  delay(200);
  mySerial.println((char)26);//the stopping character
   mySerial.println("AT+CMGS=\"+918113xxxxxx\"\r"); // change to the phone number you using
  delay(200);
  mySerial.println((char)26);//the message stopping character
  sms_count++;
and an LCD03
What IS an LCD03?
