I am trying to set up a thumper for a cranes winch response. It reads a halleffects sensor then sends a feed back to the control hanle using a megnetic thumper. I have a code that is working but my problem is when the sensor lands on a pin when stopped the thumper output stays high. I need this to resort to LOW when the signal is contant.
What would a "constant " signal look like?
The signal is a 5v constant input. When the winch motor is turning it is an interrupted input
post a schematic of your wiring?
post your code (using code tags </>)
int buttonState = 0;
int i = 0;
pinMode(2, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(10, OUTPUT);
// read the state of the pushbutton value
buttonState = digitalRead(2);
// check if pushbutton is pressed. if it is, the
// buttonState is HIGH
if (buttonState == HIGH) {
// turn LED on
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(10, HIGH);
delay(100); // Wait for 100 millisecond(s)
digitalWrite(10, LOW);
delay(50); // Wait for 50 millisecond(s)
digitalRead(10, HIGH>= 500);
// turn LED off
digitalWrite(LED_BUILTIN, LOW);
i cannot upload files being I'm a new user,sorry
Does it actually disappear or does it go to zero volts?
It goes to zero volts, when the sensor does not detect a pin on the chopper wheel, the problem is the pins are so close together that when you stop the winch 9 times out of 10 it stops on a pin that the sensor picks up and send a high(5v) back to the controller(arduino board). The code now turns that into an high/low output to activate the magnetic thumper( coil that chatters a pin in the winch control handle) it has to be high/low or it will burn the coul out rather quick
If I understand that correctly, the solution is to put the "thumper" code in a function and limit the time that function is called to some number of seconds. Does that seem like a solution?
Yes it does im thinking something like
If if pin 2 is high for more that 250 millis write to low and wait for a change of pin two state?
Kinda im reall new at this if you didnt notice.
I appreciate the help
your code (post #5) does not compile
sketch_nov04a:25:27: error: too many arguments to function 'int digitalRead(uint8_t)'
digitalRead() takes a single parameter the pin being read
there is also a ; missing off the end of the next line
use code tags </> when posting code
what Arduino are you using?
post a schematic of the circuit?
unsigned long currentTime = millis();
const unsigned long eventInterval = 250;
unsigned long previousTime = 0;
pinMode(2, INPUT);
if (digitalRead(2) >= eventInterval);
(currentTime - previousTime >= eventInterval);
/* Event code*/
/* Update the timing for the next time around */
previousTime = currentTime;
// turn LED on
else {
// turn LED off
still cnnot write 10 to low after 250 millis. it just stays in the blinking pattern
remove the ; on the end of the if() statement - it will terminate the if()
im not sure, it didnt work all i need this to do is is if the input on pin 2 is high for more than 250 milliseconds it needs to set pin 10 to low until the state of pin 2 changes back to a pulse
try this - if the input on pin 2 is high for more than 2500 milliseconds it sets pin 10 to low until the state of pin 2 changes back to low and pin 10 is set high
const unsigned long eventInterval = 2500;
unsigned long previousTime = millis();
pinMode(2, INPUT);
if (digitalRead(2) == HIGH) {
if (millis() - previousTime > eventInterval) {
// turn LED on
while (digitalRead(2) == HIGH) ; // loop until LOW
previousTime = millis(); }
else {
// turn LED off
nope that isnt working,
is there a line of code that says if digital pin two reads high for longer than 250 millis
digital write pin two to low?
const unsigned long eventInterval = 600;
pinMode(2, INPUT);
if (millis() - previousTime <= eventInterval) {
// turn LED on
delay(50);
else {
// turn LED off
THIS WORKS,
thank you very much for the help with this!!!!!
I know I've read this thread late.
Why aren't you looking for the sensor signal to go from LOW to HIGH to trigger your thumper, NOT when it is HIGH.
The transition can only happen when the wheel is moving, which is what you want.
Google;
Arduino detecting change of state
Tom...
