Need a little help finishing up a project!!!!!
I am using an UNO with an Adafruit Fingerprint Sensor and a matrix format 12 button allowing keypad.
I have code that inputs in a four digit code and is check when "#" is pressed. Works great. Also, by pressing "*" on the keypad, it initiates the fingerprint sensor. This ,almost, works great. When * is pressed it reads the fingerprint, but it only reads it once. I would like to get it to loop the fingerprint code for about 20 seconds, this gives the user time to get their finger in place. After the 20 seconds, if no fingerprint is read, it goes back to the keypad programming. Everything seems to work great except the single read. I have tried to use a loop, but have had code errors.
The code fallows:
Thanks!!!
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
#include <Password.h>
#include <Keypad.h>
int getFingerprintIDez();
int led = 13;
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 12, 11, 10 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
keypad.setDebounceTime(100);
void loop(){
keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
Serial.print("Pressed: ");
Serial.println(eKey);
switch (eKey){
case '#': guessPassword(); break;
case '*': starPressed(); break;
default:
password.append(eKey);
void guessPassword(){
Serial.print("Guessing password... ");
if (password.evaluate()){ Serial.println("VALID PASSWORD "); //
digitalWrite(5, HIGH);
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
delay(25000);
digitalWrite(5, LOW);
password.reset(); //resets password after correct entry
}else{
Serial.println("INVALID PASSWORD ");
password.reset(); //resets password after INCORRECT entry
void starPressed(){
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
Serial.println("Waiting for valid finger...");
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
digitalWrite(13, HIGH);
delay(25000);
digitalWrite(13, LOW);
return finger.fingerID;
