Using a library and its variables is not allowing the code to work
Hello everyone,,
I'm using the HX711 multi-library in my project.
However, this library is doing something so weird to my sketch and I narrow it down to this: Whenever I define the library and its variables (even without using it within the code) my whole sketch won't work including serial print function.
Here is a simple example I just did (i'm using Arduino mega):
Using this code; the LCD won't work, and not the serial monitor (Nothing happens)
#include "HX711-multi.h"
LiquidCrystal_I2C lcd(0x27, 16, 2); // Set the LCD address to 0x27 for a 16 chars and 2 line display
#define CLK 49      // clock pin to the load cell amp
#define DOUT1 A0   // data pin to the first LCA
#define DOUT2 A1  // data pin to the second LCA
#define DOUT3 A2 // data pin to the third LCA
#define TARE_TIMEOUT_SECONDS 4 //4 seconds while tare
byte DOUTS[3] = {DOUT1, DOUT2, DOUT3}; //identify the HX711 modules
#define CHANNEL_COUNT sizeof(DOUTS)/sizeof(byte) //how many hx711 are connected
long int results[CHANNEL_COUNT]; //number of modules is saved to results
HX711MULTI scales(CHANNEL_COUNT, DOUTS, CLK); //telling the library about number of scales and how are they connected and where is clock connected
const int red[] = {42, 44, 46, 48, 39, 41, 43}; //rgb lights (red pins)
    lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.print("No problem");
  for (int i = 0; i < 7 ; i++) {
   pinMode(red[i], OUTPUT);
    digitalWrite(red[i], HIGH);
  Serial.print("HI");
void loop(){
And by simply removing the HX711 library part of the above sketch, everything works
the code will become:
const int red[] = {42, 44, 46, 48, 39, 41, 43}; //rgb lights (green pins)
    lcd.init();
  lcd.backlight();
  lcd.clear();
  Serial.print("HI");
void loop(){
Please note that I followed the example given by the library to make the code.
Did I do something wrong? Why would that happen?
Have you tried the original library?
Your link states:
This is a modification of bogde's (GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales.) HX711 library for the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter for scales (load cells)
Hi @khamis98
There really is some problem with this library running on Mega arduino,
I ran on Mega and it didn't print anything.
I changed the Mega Pins to be compatible with the Mini Pins and ran it again in Mega, and nothing printed.
I ran it on the Arduino Mini, and it printed Hi on the serial monitor.
I used this lib:
#define CLK 4      // clock pin to the load cell amp
const int red[] = {5, 5, 7, 8, 9, 10, 11}; //rgb lights (red pins)
  lcd.init();
  lcd.backlight();
  lcd.clear();
  Serial.print("HI");
Yes, I have, it didn't have any problems.
However, I need to use this library because I will be using multiple load cells (even more than3)
The thing is i'm really not sure if this is a problem from the library or i did something wrong because the problem is so weird
Hello @ruilviana
Yes this is the same one
I see, then it's definitely the library itself, i was questioning everything hahahaha
Any thoughts on how to fix that?
Hello
Unlike the original library, this one doesn't have a begin method, so it does things like pinMode, digitalRead and digitalWrite in the constructor, which is called before the arduino is fully initialized. It may cause problems.
Try replace this line HX711MULTI scales(CHANNEL_COUNT, DOUTS, CLK);
By this
HX711MULTI * scales;
  scales = new HX711MULTI(CHANNEL_COUNT, DOUTS, CLK);
A better idea would be to modify this library so the constructor is only used to set up variables, and add a begin method, like in the original library
Did you attempt the example code? No LCD, just console printing.
// Pins to the load cell amp
#define CLK A0      // clock pin to the load cell amp
#define DOUT1 A1    // data pin to the first lca
#define DOUT2 A2    // data pin to the second lca
#define DOUT3 A3    // data pin to the third lca
#define BOOT_MESSAGE "MIT_ML_SCALE V0.8"
  Serial.println(BOOT_MESSAGE);
  Serial.flush();
  pinMode(11,OUTPUT);
  tare();
void tare() {
  bool tareSuccessful = false;
  unsigned long tareStartTime = millis();
  while (!tareSuccessful && millis()<(tareStartTime+TARE_TIMEOUT_SECONDS*1000)) {
    tareSuccessful = scales.tare(20,10000);  //reject 'tare' if still ringing
void sendRawData() {
  scales.read(results);
  for (int i=0; i<scales.get_count(); ++i) {;
    Serial.print( -results[i]);
    Serial.print( (i!=scales.get_count()-1)?"\t":"\n");
  delay(10);
  sendRawData(); //this is for sending raw data, for where everything else is done in processing
  //on serial data (any data) re-tare
  if (Serial.available()>0) {
    while (Serial.available()) {
      Serial.read();
    tare();
I tried this now, didn't work
How can I do that? i never modified a library before, can you share a hint ?
+1
Ray
yup I did, still nothing happens
Hi
I will search trying to understand the library
Thanks, i will do so too
The "hint" is in the original library and the begin method.
Arduino libraries are two-edged swords: when they work flawlessly, everyone sings about Arduino ease of use. When a library fails, it is like global warming and everyone screams and a few get hurt.
Without the sensors you are using, it is not reasonably appropriate to start out and library-hack in the forum; back and forth, trial and error.
Previously
khamis98
mrburnette
18m
So the original library works... that is the point to start. Study the multicell library when compared to the known good one. Hopefully you'll track down the issue. But consider that the author said the library worked, so maybe it was ArduinoIDE that changed?
Hi
What I've discovered so far:
The code does not print anything because when creating the instance on this line:
The library uses line 136 of "HX711-multi.cpp"
135: // wait for all the chips to become ready
136: while (!is_ready());
and the processing is stuck inside this whil waiting for some measurement from the HX711 module.
Theoretically, if the HX711 is mounted on the arduino, it should pass this line and print HI on the serial
But why it works with the mini arduino I don't know.
I will start with that now.... and will update the post when i'm done
OR the author didn't try it on mega
Please note that @ruilviana tried it on the Arduino mini and it worked
Alright thanks for pointing that out
