Hi, I am new to Arduino, but I am using it for my thesis research. I'm using a linear actuator to mimic the tricuspid annulus motion for a flow loop. Basically I need to be able to make the linear actuator move in a sinusoidal motion in the rhythm of a heart beat. Right now I have it moving at constant speed both ways.
My wiring is based off of the diagram on this website
My code is as follows:
// constants won't change
const int ENA_PIN = 9; // the Arduino pin connected to the EN1 pin L298N
const int IN1_PIN = 6; // the Arduino pin connected to the IN1 pin L298N
const int IN2_PIN = 5; // the Arduino pin connected to the IN2 pin L298N
// the setup function runs once when you press reset or power the board
// initialize digital pins as outputs.
pinMode(ENA_PIN, OUTPUT);
pinMode(IN1_PIN, OUTPUT);
pinMode(IN2_PIN, OUTPUT);
//digitalWrite(ENA_PIN, HIGH); automatically sets speed to max
analogWrite(ENA_PIN, 255); // speed is a value from 0 to 255
// the loop function runs over and over again forever
// extend the actuator
digitalWrite(IN1_PIN, HIGH);
digitalWrite(IN2_PIN, LOW);
delay(500); // actuator will stop extending automatically when reaching the limit
// set this to 20000 to let it extend all the way
// retracts the actuator
digitalWrite(IN1_PIN, LOW);
digitalWrite(IN2_PIN, HIGH);
delay(500); // actuator will stop retracting automatically when reaching the limit
Any help is greatly appreciated. Thanks everyone!
