If you want to try the typical application (first example - basic temperature sensor), you must use a 2k ohms, if the +Vcc is 5volts. The commercial value will be 2.2kohms. If you want to be more accurate, you can use two 1kohm resistors in series.
If the +Vcc is different, use this:
Resistor=(Vcc-3)/1000
If Vcc=5volts, resistor=2k
If Vcc=9volts, resistor=6k (use 10k in parallel with 15k)
Thankyou. Do you mind if I ask how tyou deduced this from the datasheet so I don't aske the same question again? I suspect this is an electronics 101 question - sorry
hello 4rnds I m really in a problem, pl reply I calibrated lm 335 according to d basic temp. sensing. How we can measure d temp using mercury thermometer considering lm335 basic temp sensing technq?pl help, new to dis brilliancy, regards!
hello sir, I juz want to know is it possible to know temperature through mercury thermometer directly with respect to lm335?I connected all d pins accurately, I supplied 5Volt to 2.2kohm den grnded it, I gt 24.85 temp after calculating manually, astemp(in degree c)= Vout multiply 100 - 273.15.operating output voltage is 2.98v calibrated at 25 degree c.I m new to dis field n I want to know whether we can check tepm via mercury thermo. regarding lm335? ny further applications wid potentiometer?pl rectify if I m wrong.REGARDS
thnks 4 replying sir, pl tel cn we check temperature through mercury thermometer after calibrating lm335? I got a misconception 4rm my frnds dat at a particular pin we cn measure lilbit of temp 4rm der via thermomtr.
I calibrated lm 335 n got 24.85 degree c, nt wid merc. thermom.
I am a beginner in lm335 tasks, I used some basis techniques to calibrate temperature and thus I got 25 degree c, can you provide me some more applications so that I furnish my skills in lm335?
Since am new to electronics, i would like to ask a question to see if i have cleared it all in my mind…
-I have a Vcc.
-I need to drive the output of the Temp Sensor to an analog input (ADC converter). The ADC can convert up to Vx Volts (Vx<Vcc).
(Example: Vcc=3.3V and Vx=1.2V Zigbee)
1.Whats the circuit i need to “divide” the output Voltage of the LM335?
2.Whats the theory behind all that in simple words?
3.When do i need to calibrate the Sensor? (i.e. Just bought one…does it need calibration?)
-Where as the R1 for bias.
-R2 & R3 for the voltage divider. ADC_IN = (R3/(R2+R3))*LM335_Out
-In whatever Circuit am gonna use the LM335 it will always drain 1mA? Is this correct?
I can convert max Vx. (i.e. Zigbee’s ADC can convert max Vx=1,2V. 10bit resolution mean: Vx=1,2V ADC_Out=1023 and Vx=0V ADC_Out=0)
I have Vcc>Vx (i.e. Vcc=3,3).
So using for example (R1=100, R2=200k, R3=100k) is it a 1/3 divider of the LM335 output?
Whats the general Math behind all this.
How can i compute the R’s?
And how can i cumpute the digital temp i get of the ADC back to Kelvin?
Not sure if anyone is still active on this topic, but for those interested I just used an LM335 to produce a simple little calibrated thermometer. Here's a video
recerencevoltage: analog reference voltage in mV (shoud be ~5000 for a 5v Arduino)
analogreading: Value from analogread(pin)
1024: Arduino measues analogread in 1024th's of the referece voltage - multiplying the input by the reference voltage (in mV) and dividing by the input resolution (1024) will give the input value in mV
10: input is 1mV/0.1°C; divide by 10 to give 10mV/1°C + decimals
-273.15: mesurement is in Kelvin. -273.15 to give celcius
Pilot, gOOd job I like your work, I need your help cn you elaborate the lm335 job, I want to calibrate it, but not having Arduino, I'm a beginner here. And want guidance, what you do? Please heLP, I tried it in a simple bread board!
used components are, 2.2k resister, lm335, 10k potentiometer. Now how I cn calibrate it?
I am planning on building about ten sensors, using the LM335. Sensors will be connected to Arduino boards, using RF to collect the data on a central server.
My question is about calibration. I understand how to do this with the 10K variable resistor. But I am wondering if I could do the same in software? So just collect the raw uncalibrated data, and apply a correction for each individual sensor? This would make the sensor HW smaller and easier to package.
I understand I would need to determine the correction factor on each sensor, but that would be a one-time effort.
Ideas, anyone?
I think you're missing my point. I agree that this thing needs calibration, unless you're after the level of accuracy of "it´s cold out there".
I plan to determine the offset for each and every sensor, and store that in a table. This way I can calibrate the data, instead of the hardware.
Main requirement is that the offset is linear across the range, and I suspect that it is...
Ah, OK....
What I am trying to accomplish is to add a bunch of temperature sensors to my Arduino boards that I already have running in my house.
Temp readings could be simple indoor/outdoor temperatures, but also the temp in my deepfreezer or the water in the heater.
I don't need accuracy better than 0.5 degree, even 1 degree would be good enough I think.
What puzzles me is what you say about 2 degree inaccuracy. From the datasheet I see that this can be corrected with a 10K var-resistor. It is cheap enough, but I would like to get rid of the extra component. Just the LM335 plus two 1K resistors sounds much better.
So my questions is basically: is the inaccuracy of this device linear? I don't want to go into complicated non-linear corrections.
But if it IS linear, than I can easely adapt my PHP script to apply a unique correction for each sensor.
Edit: just came to mind, I have not mentioned that I convert the readings into degrees Celsius, does this put the 2 degree inaccuracy in a new light?
Who are you calling a "young kid".... just to give you a hint about age: I started my career in ICT using Algol and Fortran, and RPG for admin type programs. But I really started enjoying myself when I moved to Assembler!
