using a look up table
Hi folks,
I have a potentiometer that controls a few things and right now I use a few mathematical equations to get the resulting action. Rather I would like to implement a look up table and have every of the 256 values mapped to do something. Say 0 to 30, turn on LED1, 30-60, LED 2.... {Just an example}
Any ideas or code examples to achieve this?
Use the bits in an 8 bit number to signify something. bit one= turn on LED 1, bit 2 = turn on LED 2...
Then create the 256 byte array:
action[256] = {1,1,1,2,2,2,3,3,...}
depending on what action. Then use bitTest() to tell what action needs to be taken.
The values are completely random, hence the need for a look up table ;)
if the distances are equal you could do
int raw = analogRead(A0);
int action = (raw * 30)/1023; //  or raw/34
switch(action)
  case 0: ...
etc
of the distances are not equal you could code the maxvalue per "section";
int sections[] = { 10, 20, 30, 40, 50, 200, 900, 1023 };  //0..10, 11..20, 21..30 etc
int action = 0;
while (raw > sections[action]) action++;
switch(action)
  case 0: ...
etc
