I used a basic example which worked with a tactile button I had but I’m trying to get it working with a 433mhz remote i have and i’m not getting any success.
Original example code:
//Global Variables
const byte BUTTON=2; // our button pin
const byte LED=13; // LED (built-in on Uno)
unsigned long buttonPushedMillis; // when button was released
unsigned long ledTurnedOnAt; // when led was turned on
unsigned long turnOnDelay = 2500; // wait to turn on LED
unsigned long turnOffDelay = 5000; // turn off LED after this time
bool ledReady = false; // flag for when button is let go
bool ledState = false; // for LED is on or not.
pinMode(BUTTON, INPUT_PULLUP);
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
// get the time at the start of this loop()
// check the button
if (digitalRead(BUTTON) == LOW) {
// update the time when button was pushed
buttonPushedMillis = currentMillis;
ledReady = true;
// make sure this code isn't checked until after button has been let go
if (ledReady) {
//this is typical millis code here:
if ((unsigned long)(currentMillis - buttonPushedMillis) >= turnOnDelay) {
// okay, enough time has passed since the button was let go.
digitalWrite(LED, HIGH);
// setup our next "state"
ledState = true;
// save when the LED turned on
ledTurnedOnAt = currentMillis;
// wait for next button press
ledReady = false;
// see if we are watching for the time to turn off LED
if (ledState) {
// okay, led on, check for now long
if ((unsigned long)(currentMillis - ledTurnedOnAt) >= turnOffDelay) {
ledState = false;
Then My modified code with the RCswitch which just removes the button and replaces it with myswitch.getReceivedValue. :
//Global Variables
#include <RCSwitch.h> //new line I've added
mySwitch.enableReceive(0); //new line I've added
// check the button
if (mySwitch.getReceivedValue() == XXXXXXX) {
// XXXXXXX = 7 digit RCswitch button code, new line I've added
ledReady = true;
if (ledReady) {
ledState = true;
ledReady = false;
if (ledState) {
ledState = false;
If i take out a few lines I can get it to turn on with the remote and a delay but then it won’t turn off so i know the rc switch is detecting my remote press, just trying to figure out why it won’t turn off with a delay.
