Using a mosfet to turn an entire breadboard into a switch
Is it possible to turn an entire breadboard into one big mosfet automatic switch? I need to do this to power down 3 sensors on said breadboard so they do not drain battery on my datalogger as it will be deployed for a month at a time. Im using an arduino nano every in which power down/sleep codes which I have no clue on how to incorporate due to code being so long. Any help is greatly appreciated.
//This code was written to be easy to understand.
//Modify this code as you see fit.
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the D.O. circuit.
//This code was written in the Arduino 1.8.9 IDE
//An Arduino UNO was used to test this code.
//This code was last tested 6/2019
/////////////////////////////////////////////////// RTC  //////////////////////////////////////
#include <Wire.h>
#include "Sodaq_DS3231.h"
char weekDay[][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat" };
#include <SoftwareSerial.h>                           //we have to include the SoftwareSerial library, or else we can't use it
#define Drx 1                                          //define what pin rx is going to be
#define Dtx 0                                         //define what pin tx is going to be
SoftwareSerial Dmyserial(Drx, Dtx);                      //define how the soft serial port is going to work
#define Erx 5                                          //define what pin rx is going to be
#define Etx 6                                          //define what pin tx is going to be
SoftwareSerial Emyserial(Erx, Etx);                      //define how the soft serial port is going to work
String Einputstring = "";                              //a string to hold incoming data from the PC
String Esensorstring = "";                             //a string to hold the data from the Atlas Scientific product
boolean Einput_string_complete = false;                //have we received all the data from the PC
boolean Esensor_string_complete = false;               //have we received all the data from the Atlas Scientific product
char *EC;                                           //char pointer used in string parsing
  float f_ec;                                         //used to hold a floating point number that is the EC
String Dinputstring = "";                              //a string to hold incoming data from the PC
String Dsensorstring = "";                             //a string to hold the data from the Atlas Scientific product
String DOVALUE="";
boolean Dinput_string_complete = false;                //have we received all the data from the PC
boolean Dsensor_string_complete = false;               //have we received all the data from the Atlas Scientific product
float DO;                                             //used to hold a floating point number that is the DO
#include <Wire.h>
#include "Adafruit_MCP9808.h"
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
float TEMPVALUE=0;
//////////////////////////////////////////////////// SD CARDS THINGS /////////////////////////////////////
#include <SPI.h>
#include <SD.h>
File fd;
const uint8_t BUFFER_SIZE = 20;
char fileEC[] = "EC.csv"; // SD library only supports up to 8.3 names
char fileDO[] = "DO.csv";
char fileTEMP[] = "TEMP.csv";
char buff[BUFFER_SIZE+2] = "";  // Added two to allow a 2 char peek for EOF state
uint8_t index = 0;
const uint8_t chipSelect = 8;
const uint8_t cardDetect = 9;
enum states: uint8_t { NORMAL, E, EO };
uint8_t state = NORMAL;
bool alreadyBegan = false;  // SD.begin() misbehaves if not first call
//    pinMode(A1, OUTPUT);     /// FOR 5V ////
//    pinMode(A2, OUTPUT);     ///// FOR 5V ///
//    pinMode(3, OUTPUT);    ///// FOR GRND ///
//    pinMode(4, OUTPUT);    ///// FOR GRND ////
    //                             digitalWrite( 3, HIGH); //// MAKING PIN HIGH OR 5V ////
//                                 digitalWrite( A2, HIGH); //// MAKING PIN HIGH OR 5V ////
   //                             digitalWrite( 4, LOW); //// MAKING PIN LOW OR 5V ////
//                                digitalWrite( 7, LOW); //// MAKING PIN LOW OR 5V ////
                                     //set up the hardware
  Serial.begin(9600);                                 //set baud rate for the hardware serial port_0 to 9600
      Wire.begin();
    rtc.begin();
  Dmyserial.begin(9600);                               //set baud rate for the software serial port to 9600
  Dinputstring.reserve(10);                            //set aside some bytes for receiving data from the PC
  Dsensorstring.reserve(30);                           //set aside some bytes for receiving data from Atlas Scientific product
    Emyserial.begin(9600);                               //set baud rate for the software serial port to 9600
  Einputstring.reserve(10);                            //set aside some bytes for receiving data from the PC
 Esensorstring.reserve(30);                           //set aside some bytes for receiving data from Atlas Scientific product
  if (!tempsensor.begin(0x18)) {
    Serial.println(F("Couldn't find MCP9808! Check your connections and verify the address is correct."));
    while (1);
   Serial.println(F("Found MCP9808!"));
  tempsensor.setResolution(3); // sets the resolution mode of reading, the modes are defined in the table bellow:
    pinMode(cardDetect, INPUT);
  initializeCard();
void EserialEvent() {                                  //if the hardware serial port_0 receives a char
 Einputstring = Serial.readStringUntil(13);           //read the string until we see a <CR>
  Einput_string_complete = true;                       //set the flag used to tell if we have received a completed string from the PC
void DserialEvent() {                                  //if the hardware serial port_0 receives a char
  Dinputstring = Serial.readStringUntil(13);           //read the string until we see a <CR>
  Dinput_string_complete = true;                       //set the flag used to tell if we have received a completed string from the PC
int b=0;
     tim();
  Serial.println(F("                  Let's DO it"));
  //here we go...
        Serial.println(F(""));
        Serial.println(F( "    DO SENSOR VALUE"));
        while( DOS()==0);
        delay(100);
         if (!digitalRead(cardDetect))
            initializeCard();
         fd = SD.open(fileDO, FILE_WRITE);
          if (fd) {
            Serial.print(F("Writing to DO.txt..."))
            ; fd.print( DO)
            ;fd.print(",");
           ;tim();
              ; fd.close();
              Serial.println(F("done."));
           Serial.println(F("error opening DO.txt"));
/////////////////////////////////////////////////////////////// EC SENSOR //////////////////////////////////
        Serial.println(F( "    CONDUCTIVIY SENSOR VALUE"));
        Serial.println(F(","));
        while ( ECOND()==0);
        delay(100);
            initializeCard();
         fd = SD.open(fileEC, FILE_WRITE);
          if (fd) {
            Serial.print(F("Writing to EC.txt..."));
             ;fd.print( f_ec);
             ;fd.print(",");
             ;tim();
              fd.close();
           Serial.println(F("error opening EC.txt"));
         ////////////////////////////////////////////////////////// TEMP ///////////////////////////////////////
        Serial.println(F( "     TEMPERATURE SENSOR VALUE"));
        MCP();
            initializeCard();
         fd = SD.open(fileTEMP, FILE_WRITE);
          if (fd) {
            Serial.print(F("Writing to TEMP.txt..."));
             ;fd.print( TEMPVALUE);
             ;fd.print(",");
             ;tim();
              fd.close();
           Serial.println(F("error opening TEMP.txt"));
/////////////////////////////////    DO /////////////////////////////
bool DOS()
  bool a=0;
  if (Dinput_string_complete == true) {                //if a string from the PC has been received in its entirety
    Dmyserial.print(Dinputstring);                      //send that string to the Atlas Scientific product
    Dmyserial.print('\r');                             //add a <CR> to the end of the string
    Dinputstring = "";                                 //clear the string
    Dinput_string_complete = false;                    //reset the flag used to tell if we have received a completed string from the PC
  if (Dmyserial.available() > 0) {                     //if we see that the Atlas Scientific product has sent a character
    char Dinchar = (char)Dmyserial.read();              //get the char we just received
    Dsensorstring += Dinchar;                           //add the char to the var called sensorstring
    if (Dinchar == '\r') {                             //if the incoming character is a <CR>
      Dsensor_string_complete = true;                  //set the flag
  if (Dsensor_string_complete == true) {               //if a string from the Atlas Scientific product has been received in its entirety
      Serial.print(F("DO = "));
    Serial.println(Dsensorstring);
    DOVALUE =    Dsensorstring;
                                                   //uncomment this section to see how to convert the DO reading from a string to a float
    if (isdigit(Dsensorstring[0])) {                   //if the first character in the string is a digit
      DO = Dsensorstring.toFloat();                    //convert the string to a floating point number so it can be evaluated by the Arduino
   a=  Dsensor_string_complete;
    Dsensorstring = "";                                //clear the string
    Dsensor_string_complete = false;                   //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
   // Serial.println(a);
  return a;
int ECOND()
  int a=0;
  if (Einput_string_complete == true) {                //if a string from the PC has been received in its entirety
   Emyserial.print(Einputstring);                      //send that string to the Atlas Scientific product
    Emyserial.print('\r');                             //add a <CR> to the end of the string
    Einputstring = "";                                 //clear the string
    Einput_string_complete = false;                    //reset the flag used to tell if we have received a completed string from the PC
  if (Emyserial.available() > 0) {                     //if we see that the Atlas Scientific product has sent a character
    char Einchar = (char)Emyserial.read();              //get the char we just received
    Esensorstring += Einchar;                           //add the char to the var called sensorstring
    if (Einchar == '\r') {                             //if the incoming character is a <CR>
      Esensor_string_complete = true;                  //set the flag
  if (Esensor_string_complete == true) {               //if a string from the Atlas Scientific product has been received in its entirety
    if (isdigit(Esensorstring[0]) == false) {          //if the first character in the string is a digit
      Serial.println(Esensorstring);                   //send that string to the PC's serial monitor
    else                                              //if the first character in the string is NOT a digit
      Eprint_EC_data();                                //then call this function
    a=Esensor_string_complete;
   Esensorstring = "";                                //clear the string
    Esensor_string_complete = false;                   //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
  return a;
void Eprint_EC_data(void) {                            //this function will pars the string
  char Esensorstring_array[30];                        //we make a char array
  char *TDS;                                          //char pointer used in string parsing
  char *SAL;                                          //char pointer used in string parsing
  char *GRAV;                                         //char pointer used in string parsing
  Esensorstring.toCharArray(Esensorstring_array, 30);   //convert the string to a char array
  EC = strtok(Esensorstring_array, ",");               //let's pars the array at each comma
  TDS = strtok(NULL, ",");                            //let's pars the array at each comma
  SAL = strtok(NULL, ",");                            //let's pars the array at each comma
  GRAV = strtok(NULL, ",");                           //let's pars the array at each comma
  Serial.print(F("EC:"));                                //we now print each value we parsed separately
  Serial.println(EC);                                 //this is the EC value
  Serial.print(F("TDS:"));                               //we now print each value we parsed separately
  Serial.println(TDS);                                //this is the TDS value
  Serial.print(F("SAL:"));                               //we now print each value we parsed separately
  Serial.println(SAL);                                //this is the salinity value
  Serial.print(F("GRAV:"));                              //we now print each value we parsed separately
  Serial.println(GRAV);                               //this is the specific gravity
  //Serial.println();                                   //this just makes the output easier to read
f_ec= atof(EC);                                     //uncomment this line to convert the char to a float
void MCP()
//   Serial.println("wake up MCP9808.... "); // wake up MCP9808 - power consumption ~200 mikro Ampere
//  tempsensor.wake();   // wake up, ready to read!
  // Read and print out the temperature, also shows the resolution mode used for reading.
//  Serial.print("Resolution in mode: ");
//  Serial.println (tempsensor.getResolution());
  float c = tempsensor.readTempC();
  float f = tempsensor.readTempF();
  Serial.print("Temp: ");
  Serial.print(c, 4); Serial.print(F("*C\t and "));
  Serial.print(f, 4); Serial.println(F("*F."));
  TEMPVALUE =tempsensor.readTempF();
 // delay(2000);
//  Serial.println("Shutdown MCP9808.... ");
//  tempsensor.shutdown_wake(1); // shutdown MSP9808 - power consumption ~0.1 mikro Ampere, stops temperature sampling
  Serial.println("");
  delay(100);
//////////////////////////////////////////// CARD  /////////////////////
void initializeCard(void)
  Serial.print(F("Initializing SD card..."));
  // Is there even a card?
    Serial.println(F("No card detected. Waiting for card."));
    while (!digitalRead(cardDetect));
    delay(250); // 'Debounce insertion'
  // Card seems to exist.  begin() returns failure
  // even if it worked if it's not the first call.
  if (!SD.begin(chipSelect) && !alreadyBegan)  // begin uses half-speed...
    Serial.println(F("Initialization failed!"));
    initializeCard(); // Possible infinite retry loop is as valid as anything
    alreadyBegan = true;
  Serial.println(F("Initialization done."));
  Serial.print(fileEC);
  if (SD.exists(fileEC))
    Serial.println(F(" exists."));
    Serial.println(F(" doesn't exist."));
  Serial.print(fileDO);
  if (SD.exists(fileDO))
    Serial.println(F(" doesn't exist. "));
  Serial.print(fileTEMP);
  if (SD.exists(fileTEMP))
 Serial.println(F(" CARD INITIALIZATION DONE "));
void tim()
      DateTime now = rtc.now(); //get the current date-time
    uint32_t ts = now.getEpoch();
//    if (old_ts == 0 || old_ts != ts) {
//  old_ts = ts;
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.date(), DEC);
  Serial.print(' ');
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.print(' ');
  fd.print(now.year(), DEC);
 fd.print('/');
 fd.print(now.month(), DEC);
 fd.print('/');
 fd.print(now.date(), DEC);
 fd.print(' ');
 fd.print(now.hour(), DEC);
 fd.print(':');
 fd.print(now.minute(), DEC);
 fd.print(':');
 fd.print(now.second(), DEC);
 fd.print(' ');
 ;fd.println();
Consult the sensor data sheets for their behaviour on power up.
Or try a high-side switch for the sensors and find out what happens on power up/down. The sensors may suck current from their I/O pins even with Vcc removed.
Power them off a single power segment on the board. Then just switch the power to that segment.
You need to consider what this will do to the sensors too.
But! using a breadboard for something that is expected to operate correctly for a month is asking for trouble. There are much better ways!
Paul
This project Long Life On/Off Remote WiFi, Bluetooth, BLE, Radio/LoRa or SMS has a circuit for a Fet controlled battery supply for Arduino.
Press the button to turn on, the arduino latches up the fet, when the arduino is finished it just turns itself off (or you could use a pushbutton input to the arduino to trigger that turn off)
Yes, you must account for the possibility.
At least anything connected to microprocessor output pins can usually be dealt with by setting them LOW or even turning them into INPUT pin modes.
A good meter will help you find small currents stealing your idea of low power.
As will thinking about it hard. :wink:
a7
