Using a Nano and DFPlayer for custom phrases
I am trying to reprogram a See N Say with a Nano (ATmega328P) and a DFPlayer to say custom phrases but I cannot get it to work. I found Andrei Aldea’s guide online and have been following it to the best of my ability. I have the board from the See N Say wired to their respective inputs on the Nano and the Rx and Tx lines going to the DFPlayer but nothing seems to work. It is supposed to say a greeting once the board is powered on but I haven’t heard it yet. The DFPlayer works when I use tweezers to ground and IO2 so I know the problem isn’t with them.
I am trying to figure out if the fault lies within the code or in the hardware.
Any suggestions?
The forum won’t let me add pictures
 EEV See N' Say++
 Andrei Aldea
 January 2019
 Uses DFPlayer - A Mini MP3 Player For Arduino from <https://www.dfrobot.com/index.php?route=product/product&product_id=1121>
 Uses Library by Angelo Qiao for said device.
 Made to run on an Arduino Nano/Uno or other compatibles
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(1, 2); // RX, TX for MP3 module
DFRobotDFPlayerMini myDFPlayer;
    pinMode(A5, INPUT_PULLUP); //Because for some weird reason A7 INPUT_PULLUP causes AVR-GCC to seg-fault at the time of writing
    pinMode(5, INPUT_PULLUP);
    pinMode(6, INPUT_PULLUP);
    pinMode(7, INPUT_PULLUP);
    pinMode(8, INPUT_PULLUP);
    pinMode(9, INPUT_PULLUP);
    pinMode(10, INPUT_PULLUP);
    pinMode(11, INPUT_PULLUP);
    pinMode(12, INPUT_PULLUP);
    pinMode(14, INPUT_PULLUP);
    pinMode(15, INPUT_PULLUP);
  mySoftwareSerial.begin(9600);
 // Serial.begin(9600); --Serial Port Taken up because I used Pin 1 for Matrix
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3, wait for module
    while (true);
  myDFPlayer.volume(25);  //Set volume value. From 0 to 30
  myDFPlayer.play(int(random(0,3)));  //Play the first mp3 - Make Dave Say Hi
  //Should have all been a CASE statement but copy-paste is easy.
  if (digitalRead(A5) == HIGH) //If the page is NOT flipped
    if(!digitalRead(5))
      myDFPlayer.playFolder(1, int(random(1,14)));  //play specific mp3 in SD:/15/004.mp3; Folder Name(1~99); File Name(1~255)
      delay(200); //Debounce
    if(!digitalRead(6))
      myDFPlayer.playFolder(2, int(random(1,17)));
    if(!digitalRead(7))
      myDFPlayer.playFolder(3, int(random(1,50)));
        if(!digitalRead(8))
      myDFPlayer.playFolder(4, int(random(1,5)));
        if(!digitalRead(9))
      myDFPlayer.playFolder(5, int(random(1,25)));
        if(!digitalRead(10))
      myDFPlayer.playFolder(6, int(random(1,18)));
        if(!digitalRead(11))
      myDFPlayer.playFolder(7, int(random(1,23)));
        if(!digitalRead(12))
      myDFPlayer.playFolder(8, int(random(1,11)));
        if(!digitalRead(14))
      myDFPlayer.playFolder(9, int(random(1,30)));
        if(!digitalRead(15))
      myDFPlayer.playFolder(10, int(random(1,13)));
  else //Page is flipped
    if(!digitalRead(5))
      myDFPlayer.playFolder(11, int(random(1,39)));
    if(!digitalRead(6))
      myDFPlayer.playFolder(12, int(random(1,21)));
    if(!digitalRead(7))
      myDFPlayer.playFolder(13, int(random(1,20)));
        if(!digitalRead(8))
      myDFPlayer.playFolder(14, int(random(1,12)));
        if(!digitalRead(9))
      myDFPlayer.playFolder(15, int(random(1,7)));
      myDFPlayer.playFolder(16, int(random(1,8)));
      myDFPlayer.playFolder(17, int(random(1,6)));
      myDFPlayer.playFolder(18, int(random(1,13)));  //Right now this is a placeholder - no sounds will play as none are on SD
      myDFPlayer.playFolder(19, int(random(1,13)));  //Right now this is a placeholder - no sounds will play as none are on SD
      myDFPlayer.playFolder(20, int(random(1,2)));  //Some Tek Syndicate / Wendell from Level1Techs sounds
The forum won't let me add pictures
Bottom right of your post
More > Modify
Edit your post, there is a function for attachments. Attach your images. jpg will automatically be displayed. There is a file size limit so you might have to edit the images first to reduce the file size.
I don't know the answer to your question, but I didn't understand how you have it wired.
