using a photo detector to rotate servo
Here is my code so far. ive gotten the servo to turn on but the servo doesn't turn. Im using Arduino uno. Any advice???
#include <Servo.h>
int servoPin=9;
int lightVal;
int servoPos = lightVal;
Servo myServo;
int lightPin = A0;
int DT=250;
myServo.attach(servoPin);
pinMode(lightPin,INPUT);
lightVal=analogRead(lightPin);
delay(DT);
Serial.print(" the servo is at angle ");
Serial.println(lightVal);
while (Serial.available() ==0) {
servoPos=analogRead(lightVal);
myServo.write(servoPos);
servoPos=analogRead(lightVal); makes no sense. lightVal isn't a pin number.
Steve
nhorn12:
Yes, please read the sticky post at the top of the forum about how to properly post your code using code tags. It helps people help you
#include <Servo.h>
int servoPin=9;
int lightVal;
Servo myServo;
int lightPin = A0;
int DT=250;
  delay(DT);
You probably want
servoPos=lightVal;
instead of
The latter one doesn't make any sense, have a look at the API for analogRead.
Also, think about the ranges of values for lightVal and servoPos. Probably you want to perform some mapping between them.
