Using a photoresistor with arduino
I am using a photoresistor to measure light source, but when I put it in, nothing happens.
My code is
  Serial.println(analogRead(A0) * (5.0 / 1023));
Any help would be appreciated.
How are things wired?
Make sure you have a resistor (10k for example) from the 5v to A0 then the sensor to ground.
You need a source of volts to read it. This forms a voltage divider with a variable resistance being the sensor.
Weedpharma
Welcome....
A forum rule of thumb is to post your code and a schematic of how you have things hooked up: it's well nigh impossible to help otherwise.
The use of a photoresistor in the voltage divider configuration is explained here at adafruit with code and schematic.
Actually, if you use Google you’ll find a multitude of examples.
It helps to put the word “arduino” at the beginning of your search to screen out PIC examples.
photo resistor examples with arduino
