I'm trying to use a potentiometer as a method to adjust the sensitivity for color-changing LED to be used as a party light.
The idea is that an LED will display a specific color if a defined threshold is met; however, I want to adjust that value relative to the setting on a potentiometer.
Therefore if music is quieter I can adjust the threshold down or vice versa
How I'm reading the potentiometer value currently
float SensitivityValue = analogRead(Sensitivity);
Serial.println((SensitivityValue)/1023);
I am able to read the state of the potentiometer easily and I've been able to a value between 0.00 and 1. However, I want to try and get a value between 0.5 (Max potentiometer) and 1 (Min). Because I intend to divide my threshold value by the Sensitivity value in order to increase it.
Code snippet of how the threshold works.
else if (value > ( 520 / SensitivityValue) && value <= (525 / SensitivityValue))
Serial.println("Yellow"); // Value
RGBColor(255, 255, 0);
I would also appreciate any other suggestions on how to accomplish this.
Why not read the analogue value and use the map() function to map it to the range that you require, or even easier, use the raw value to determine the threshold
