Hi, right now I have a potentiometer controlling a 7 segment display by displaying a number based on a value given off by the potentiometer, so if I turn the potentiometer completely it will display the number 9. This is my current code:
// Pin 2-8 is connected to the 7 segments of the display.
// Pin 0 is for potentiometer
int potentiometer = 0;
int potval;
int pinA = 2;
int pinB = 3;
int pinC = 4;
int pinD = 5;
int pinE = 6;
int pinF = 7;
int pinG = 8;
// the setup routine runs once when you press reset:
// initialize the digital pins as outputs.
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
potval=analogRead(potentiometer);
if (potval>=0 && potval<=101){
//0
digitalWrite(pinA, LOW);
digitalWrite(pinB, LOW);
digitalWrite(pinC, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
digitalWrite(pinG, HIGH);
else if (potval>=102 && potval<=203){
//1
digitalWrite(pinA, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
else if (potval>=204 && potval<=305){
//2
digitalWrite(pinC, HIGH);
digitalWrite(pinG, LOW);
else if (potval>=306 && potval<=407){
//3
else if (potval>=408 && potval<=509){
//4
else if (potval>=510 && potval<=611){
//5
digitalWrite(pinB, HIGH);
else if (potval>=612 && potval<=713){
//6
else if (potval>=714 && potval<=815){
//7
else if (potval>=816 && potval<=917){
//8
else if (potval>=917 && potval<=1023){
//9
What I am trying to do is make it so if I turn the potentiometer completely, it will display all the numbers from 0-9 after a delay and if I turn it half way, it displays all the numbers from 0-5 after a delay, So, how would I go about doing this? Thanks in advance.
