Using a relay to trigger Arduino
Hey All,
I tried searching but didn't find what I am looking for so hopefully it hasn't been asked before.
I have an Arduino program setup and running a stepper motor sequence. That's all working fine, triggered with a push of a button.
What I would like to do now is have that program triggered by an existing machine/outside circuit (Not an Arduino) . The circuit has higher voltage than the Arduino can handle.
Is the best way to make this work to use a relay that will close a trigger circuit for the Arduino?
I hope this makes sense.
A relay contact will work.
An opto isolator will work.
A simple transistor will work.
Does you machine have a common electrical ground that can connect to the Arduino gorund? If not, then relay or opto-isolator is the answer.
Paul
Octo - Isolator! ... Perfect!
Thank you!
I have knowledge of programming, but it's been far to long since I have dealt with any circuits and components like this. This is perfect.
looped:
Thank you!
NO! Opto-isolator. As in optical isolator!
Paul
lol ... Damn auto correct.
Opto ... Got it.
