using a relay to turn on a 12 V device
Just wanted to make sure I'm doing this the right way. I'd like to use a digital I/O pin from the arduino to turn on (close) a 12 V circuit.
If I'm not mistaken the way one does this by using a relay. According to my reading you need a 2n2222 transistor in there to keep the chip safe during the relay's switching operations.
So:
arduino digital I/O---resistor ?k ohms----transistor-----relay-----12V +
arduino gnd -----------transistor------relay----12V grd
I'm stumped.
Simply put I want a 12V circuit to complete (turn on) when I send the HI signal to a digital out pin on the arduino.
There is an example in the playground, Arduino Playground - HomePage.
In particular, don't skip that diode. I mention this because you didn't. That keeps your relay coil from making a 100V+ spike when you turn it off. That can be a pin or chip killer.
gotcha, that makes some sense. In the diagram what does the symbol with the box with a line through it mean. It is labeled K1 and looks like it breaks out to refer to a simple switch (?).
hi
K1 is the relay...
D
...that's why it look like a switch in the little dotted breakout diagram.
Thanks for the hand-holding guys. I'm not a hardware guy, more of a software guy. I guess it shows... ::slight_smile:
that's ok, I am a hardware guy.. maybe one day I'll have a software question :slight_smile:
