Using a sequence of numbers saved in EEprom to drive a GSM shield
I can record a number of Arduino EEPROM and can read but can not use the number saved with the AT commands of the GSM module can someone give me a hint
#include <EEPROM.h>
int c;
char *numero= "11999999999";
void setup(){
  escreve_numero(numero,1);
  int a = 1;
  int b = 12;
  ler(a,b);
//  le_numero(0,1);
void escreve_numero(char *n, unsigned pos)
    for (; *n; n++, pos++) {
      Serial.print(pos);Serial.print(" : ");Serial.println(*n);
      EEPROM.write(pos, *n);
    EEPROM.write(pos, '\0');
    Serial.println("------");
void ler(int ini, int fim)
    for (int x=ini; x<fim; x++) {
      Serial.print(x);Serial.print(" : ");
      char c = EEPROM.read(x);
      Serial.println(c);
void le_numero(char *n, unsigned pos)
    do {
       int c = EEPROM.read(pos++);
       *n++ = c;
    } while (c != '\0');
void loop(){}
