Using a servo with LDR to turn a solar panel
This is the code that I use but I still need to insert a second LDR. My servo stops now with one LDR. But what do I insert for another LDR?
#include <Servo.h>
Servo myservo;                                                    //name servo
int photocellPin = A0;                                             //define photo cell reading input
int photocellReading;                                             //define photo cell reading variable
int shadeOpen = 0;
int shadeClosed = 0;
  Serial.begin(9600);                                             //initiate serial @ 9600 baud
  myservo.attach(11);                                             //define pin 11 as servo signal pin
  Serial.print("Brightness = ");                                  //print "Brightness = "
  Serial.println(photocellReading);                               //print the photocell reading
  photocellReading = analogRead(photocellPin);                    //define photocellReading as pin 0 input from LDR
  photocellReading = map(photocellReading, 0, 1023, 0, 179);      //map the LDR input to a value between 1-180 so the servo can understand it
  if (photocellReading <= 70 && shadeClosed == 0)                 //if the LDR is showing darkness and the shade isn't closed already
      myservo.write(110);                                         //then tell the servo to rotate forwards at a steady rate (close shade)
      delay(2500);                                                //2.5 second delay while shade is closing
      myservo.write(95);                                          //stop rotation after dalay
      shadeClosed = 1;                                            //set shadeClosed var as true
      shadeOpen = 0;                                              //set shadeOpen var as false
  else if (photocellReading >= 110 && shadeOpen == 0)             //if the LDR is showing light and the shade isn't open already
      myservo.write(70);                                          //then tell the servo to rotate backwards at a steady rate (open shade)
      delay(2500);                                                //2.5 second delay while shade is opening
      shadeOpen = 1;                                              //set shadeOpen var as true
      shadeClosed = 0;                                            //set shadeClosed var as false
  delay(1);
