I have a project that uses an Adafruit Sound FX board. I have a project that requires hundreds of audiophiles stored on the sound effects board. Each filename has a number. I would like to be able to play a track by the filename number (not the track number) without needing to have a bunch of switch cases.
I've tried this:
x = 1001;
String fullFilename = (x + "WAV");
sfx.playTrack( fullFilename.c_str());
and I get error:
call of overloaded 'playTrack(const char*) is ambiguous.
What does this mean, and what do I need to change to make this work?
system
March 4, 2016, 2:27pm
2
An audiophile is someone who loves good audio. How are you storing a person on the board?
An audio file, on the other hand...
No, each file has a name that contains the string representation of a number.
x = 1001;
So, the file name is 1001WAV? That seems unlikely. More likely, the name is 1001.WAV.
In any case, there is no reason to piss away resources on the String class.
char fileName[16];
sprintf(fileName, "%d.wav", x);
sfx.playTrack(fileName);
Remove the . if you REALLY didn't use the . in the file name.
What does this mean
It means that the function takes a char *, not a const char *. The String::c_str() method returns a const char *.
Quit using Strings. Sledgehammers are not flyswatters.
Thanks, it does what I needed.... But I have to wonder why when I use your method it makes my sketch significantly larger than with 20 switch cases.
system
March 5, 2016, 4:23pm
4
Because you are doing something wrong. I presume you know that, which is why you didn't share the code.
Lol. You caught me. Here you go. The code is below. Since you seem fond of jumping to conclusions, I figured I'd also include a screen capture to save you from needing to actually run the sketch for yourself. The sound library is on adafruit's site.
9,480bytes:
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
#define SFX_TX 10
#define SFX_RX 11
#define SFX_RST 12
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
int soundtrack = 1007;
void setup(){
ss.begin(9600);delay(2000);
sfx.reset();
void loop(){
char fileName[16];
sprintf(fileName, "%d WAV", soundtrack);
delay(5000);
versus 8,192 bytes:
#define SFX_TX 10
#define SFX_RX 11
#define SFX_RST 12
void setup(){
sfx.reset();
void loop(){
switch (soundtrack){
case (1001): { sfx.playTrack("1001 WAV"); break;}//Alarm
case (1004): { sfx.playTrack("1004 WAV"); break;}// calibrating
case (1005): { sfx.playTrack("1005 WAV"); break;}// complete
case (1006): { sfx.playTrack("1006 WAV"); break;}// demo mode
case (1007): { sfx.playTrack("1007 WAV"); break;}// final snooze
case (1008): { sfx.playTrack("1008 WAV"); break;}// off
case (1009): { sfx.playTrack("1009 WAV"); break;}// on
case (1010): { sfx.playTrack("1010 WAV"); break;}// percent
case (1011): { sfx.playTrack("1011 WAV"); break;}// power off
case (1012): { sfx.playTrack("1012 WAV"); break;}// release time
case (1013): { sfx.playTrack("1013 WAV"); break;}// reset
case (1015): { sfx.playTrack("1015 WAV"); break;}// settings saved
case (1017): { sfx.playTrack("1017 WAV"); break;}// settings
case (1018): { sfx.playTrack("1018 WAV"); break;}// sit time
case (1021): { sfx.playTrack("1021 WAV"); break;}// waiting
case (1022): { sfx.playTrack("1022 WAV"); break;}// seconds
case (1023): { sfx.playTrack("1023 WAV"); break;}// minutes
case (1025): { sfx.playTrack("1025 WAV"); break;}// sound
case (1026): { sfx.playTrack("1026 WAV"); break;}// snooze
case (1027): { sfx.playTrack("1027 WAV"); break;}// connected
delay(5000);
system
March 6, 2016, 12:43am
6
Does the second code even work? Spaces in file names are highly unusual in 8.3 format file names.
No dot in the file name is highly unusual in 8.3 format file names.
The spaces without the dot ARE necessary for this board.
Now, how about the differences in sketch sizes? What can you tell me about that?
Just noticed the audiophile thing... that's sire's little joke I guess. This board doesn't have the storage capacity to store audiophiles.
system
March 6, 2016, 2:01pm
8
sprintf() is a powerful function. Along with that power comes an increase in code size.
But, what you are comparing, size-wise, is not code that you posted initially. The code you posted last does not use the String class, while the first code you posted does.
If you don't need all the power of sprintf(), you could use itoa() to convert the int to a string (unformatted) and then use strlen(), strcpy(), and strcat() to construct the file name. The resulting code will be smaller than with sprintf(), but will be more complex.
