I want to use a table to print out the exact temperature reading relevant to the reading of a thermister connected to say analogue 1.
My thoughts are that I calibrate the thermister in hot water and with the actual readings from analogue 1 and a separate thermometer should end up with a table something like this (actual values are irrelevant just an example)
i am only interested in a small temp range which from memory was about 300 to about 900 (analogue1 input) that's about 30c to 90c and I do not need to be that accurate maybe 1 or 2 degrees C.
Its just so that I can get an idea of just how hot my BIO is during the process.
Thanks John :D :D :D
Just had a look at the link.
Can I just ask if you think I have understood it.
It is taking 0 to 1023 and mapping it to 0 to 255.
After reading analogue (0) it is taking the read value (val) converting it and calling it (val) and outputting it to pin 9 as another analogue value between 0 to 255.
So if my range were say 300 to 900 equating to 20c to 90c ( it would be fairly linear over this range) then my analogue output value would be somewhere between 20 to 90c.
Presumably instead of analogue writing this to an output I could send this value (val) to the serial port. I could also use this value in my calculations for telling the sketch when my oil is at a certain temp.
If my understanding is correct that is brillient, I didn't think it would be so easy, a lot easier than plotting all the values between 300 to 900 (20 to 90) as I would have to do in a table
It is taking 0 to 1023 and mapping it to 0 to 255]
It's just an example of mapping one range (0..1023) to another (0..255) - the key thing is the "map" function.
You can specify any values you like (even negative ones), though the function is limited to integer values.
I think there's a similar floating-point version somewhere where can can specify linearity.
Thanks guy's
Just spent most of the afternoon with a cup of scolding hot water and a thermometer.
I used the script in the first link and added serialprint commands after the first (val) definition and also after the conversion.
It works quite well, I seem to have fluctuations on the analogue read which I thought might be due to a noisy 5volt so I connected the thermister to the 3v... didn't make much difference but its not a real problem and really 90c and 50c are my two main points, if they are reasonably close the other readings are just for show
I just need to wait for a cup of water to freeze in the deep freeze then I can set my lower value more accurately
Thanks again guy's
John
;D ;D ;D
PS the fscale command was too complicated for me... but thanks anyway....
Hi Guy's
I just thought I would update you on my progress.
I found that because of non linearity of the thermister, if I set the max and min at freezing and boiling my main points (50c and 90c) were wildly out (90 wasn't bad cuz thats near boiling) but if I set max at 90 and min at 50 those two points worked out well and I still get readings outside these points which are reasonable and useful for my purpose.
They don't go off too far until temp gets down to about 20c which I am not interested in.
