Hi, I am very new to coding and I am trying to find a way to make a USB keyboard control a Servo motor via a USB Host Cable with a Teensy 4.1. I understand that the two main codes that I have been looking at so far may not be able to be related, but they both work in a way that I could test to see if they worked so I've been trying to figure out a way to use them. If anyone could shed some light on this or point me to a resource I might find helpful it would be greatly appreciated!
The first one is a code that allows me to move a servo via the USB keyboard plugged directly into my laptop with the buttons "a" and "d". The second one is a code that confirms to me that the keyboard is being read by the Teensy via the USB Host Cable and then displayed in the serial monitor in the Arduino IDE.
#include <Keyboard.h>
#include<PWMServo.h> // include server library
PWMServo servo; // create servo object to control a servo
int poser = 0; // initial position of server
int val; // initial value of input
Serial.begin(9600); // Serial comm begin at 9600bps
servo.attach(9);// server is connected at pin 9
if (Serial.available()) // if serial value is available
val = Serial.read();// then read the serial value
if (val == 'd') //if value input is equals to d
poser += 20; //than position of servo motor increases by 20 ( anti clockwise)
servo.write(poser);// the servo will move according to position
delay(15);//delay for the servo to get to the position
if (val == 'a') //if value input is equals to a
poser -= 20; //than position of servo motor decreases by 20 (clockwise)
#include "USBHost_t36.h"
USBHost myusb;
KeyboardController keyboard1(myusb);
while (!Serial) ; // wait for Arduino Serial Monitor
myusb.begin();
keyboard1.attachPress(OnPress);
void OnPress(int key)
switch (key) {
case KEYD_INSERT : Serial.print("Ins"); break;
default: Serial.print((char)key); break;
