so, recently I have been looking in to a project about using a wii nunchuck as a controller by using the 3 axis accelerometer to control multiple servos in a robotic arm , however I still do not understand how to do this as the wii nunchuck adapter has 4 connected things, 1 for power( 3.3V I think) , the negative wire to ground, the one at goes in to the analog 4 and one that goes in analog 5. What do these two analogs signals do? I presume that they control the accelerometer and joystick, so how do you use the C and Z buttons, anyway when programming it at the start What you should it in the setup part, would you only use 1 variable for all axis of the accelerometer and then a similar thing for the joystick across x and y, also due to the c and z buttons not going directly into a Port e.g. Digital 9 how would you define them in the setup?
If you have any of the code for the setup and anything else I would be very great full!
They are the I2C buss which communicates with the electronics inside the nunchuck.
// Nunchuck test
// By Mike Cook
#include <I2C.h>
int outbuf[6]; // array to store results
void setup () {
Serial.begin (19200);
I2c.begin();
I2c.pullup(0); // disable I2C pull ups
I2c.timeOut(500); // half a second to prevent lock up
Serial.print ("Finished setup\n");
nunchuck_init (); // send the initialisation handshake
void nunchuck_init () {
// I2c.write(address, registerAddress, data) // set up start of read
I2c.write(0x52, 0x40, 0x00);
void send_zero () {
I2c.write(0x52, 0x00);
void loop () {
// I2c.read(address, numberBytes)
Serial.println(" ");
Serial.println("Raw data");
I2c.read(0x52, 6);
for(int j=0; j<6; j++){ // now get the bytes one at a time
outbuf[j] = I2c.receive(); // receive a byte
if(outbuf[j] < 0x10) Serial.print("0"); // print leading zero if needed
Serial.print(outbuf[j], HEX); // print the byte
Serial.print(" ");
Serial.println(" "); // new line
printResults();
send_zero (); // send the request for next bytes
delay (800);
// Print the input data we have received
// accel data is 10 bits long
// so we read 8 bits and the LS bits are in the last byte
void
printResults ()
int z_button = 0;
int c_button = 0;
// byte outbuf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
z_button = outbuf[5] & 1;
c_button = 1 ^ ((outbuf[5] >> 1) & 1) ^ (outbuf[5] & 1);
outbuf[2] = (outbuf[2] << 2) | (outbuf[5] >> 2) & 0x3; // acc x
outbuf[3] = (outbuf[3] << 2) | (outbuf[5] >> 4) & 0x3; // acc y
outbuf[4] = (outbuf[4] << 2) | (outbuf[5] >> 6) & 0x3; // acc x
for(int i=0; i<5; i++){
Serial.print (outbuf[i], DEC);
Serial.print ("\t");
Serial.print (z_button, DEC);
Serial.print (c_button, DEC);
You will also need the I2C master library not the normal wire one, find it at:-
