Using accelstepper and a I2C display
I am trying to get my steppers running using the accelstepper library.
Also having a I2C display connected to the system.
But if i want to run the motor at some speed i notice that the motor is not running continuously but its looks that there is a pause in the movement.
Is this normal behaviour using this library and if so how should i solve this?.
All the examples, they have not much code, are running normal.
Harry
Then, clearly, the problem is YOUR code. Fix it.
If you need help, not posting your code is not how to get it.
