I am using an adafruit ultimate GPS module. I have had this wired up and working and printing the data so I know it works. Now I am looking to use the code and put it into a larger project. To start simple I have simply tried to have the main loop which then calls another loop that reads the GPS and then converts it into a number of varibales which can be combined into a csv string that at a later date I can write to an SD card with data from other sensors. However, when using the code I have it is not getting the data from the GPS and putting it in my string when calling it in a different loop, I think that this is something to do with the timing of the GPS library however i dont understand the library properly so any help would be appreciated. Heres the code I have tried:
#include <SoftwareSerial.h>
#include <Adafruit_GPS.h>
#define GPSECHO true
String datastring, h, m, s, D, M, Y, f, q, LAT, VERT, LON, HOR, S, A, ALT, SAT, title;
int hour;
int minute;
int seconds;
int day;
int month;
int year;
int fix;
int quality;
float Lat;
char NS;
float Lon;
char EW;
float Speed;
float Angle;
float Altitude;
int Satellites;
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
// Connect the GPS TX (transmit) pin to Digital 8
// Connect the GPS RX (receive) pin to Digital 7
// If using hardware serial:
// Connect the GPS TX (transmit) pin to Arduino RX1 (Digital 0)
// Connect the GPS RX (receive) pin to matching TX1 (Digital 1)
// If using software serial, keep these lines enabled
// (you can change the pin numbers to match your wiring):
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
// If using hardware serial, comment
// out the above two lines and enable these two lines instead:
//Adafruit_GPS GPS(&Serial1);
//HardwareSerial mySerial = Serial1;
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
title = String("Hour, Minute, Secconds, Day, Month, Year, fix, quality, Latitude, Longitude, Speed, Angle, Altitude, Satellites");
Serial.println(title);
void loop(){
Read_GPS();
datastring = String(h + ',' + m + ',' + s + ',' + D + ',' + M + ',' + Y + ',' + f + ',' + q + ',' + LAT + VERT + ',' + LON + HOR + ',' + S + ',' + A + ',' + ALT + ',' + SAT);
Serial.println(datastring);
delay(2000);
uint32_t timer = millis();
void Read_GPS() // run over and over again
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if ((c) && (GPSECHO))
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (timer > millis()) timer = millis();
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
h = String(hour = GPS.hour);
m = String(minute = GPS.minute);
s = String(seconds = GPS.seconds);
D = String(day = GPS.day);
M = String(month = GPS.month);
Y = String(year = GPS.year);
f = String(fix = GPS.fix);
q = String(quality = GPS.fixquality);
LAT = String(Lat = GPS.latitude);
VERT = String(NS = GPS.lat);
LON = String(Lon = GPS.longitude);
HOR = String(EW = GPS.lon);
S = String(Speed = GPS.speed);
A = String(Angle = GPS.angle);
ALT = String(Altitude = GPS.altitude);
SAT = String(Satellites = GPS.satellites);
