Using an Apple Remote with Arduino and a IR-sensor
A lot of Apple products ships with the small white IR remote and i was wondering if anybody have used this to control a Arduino using an IR-sensor?
actually i did it today. i'm not 100% happy with the results, it works but not very reliable. i just used a resistor, maybe i need a capacitor as well?
here is my code:
int ir_pin = 2;                        //Sensor pin 1 wired through a 220 ohm resistor
int led_pin = 13;                  //"Ready to Recieve" flag, not needed but nice
int debug = 1;                        //Serial connection must be started to debug
int start_bit = 2000;                  //Start bit threshold (Microseconds)
int bin_1 = 1000;                  //Binary 1 threshold (Microseconds)
int bin_0 = 400;                  //Binary 0 threshold (Microseconds)
  pinMode(led_pin, OUTPUT);            //This shows when we're ready to receive
  pinMode(ir_pin, INPUT);
  digitalWrite(led_pin, LOW);              //not ready yet
  int key = getIRKey();                    //Fetch the key
  Serial.println(result);              //sends result to serial for debugging
int getIRKey() {
  int data[31];
  int keysequence[5];
  digitalWrite(led_pin, HIGH);         //Ok, i'm ready to recieve
  while(pulseIn(ir_pin, HIGH) < start_bit) { //Wait for a start bit
  for(int i=0;i<31;i++) {
  data[i] = pulseIn(ir_pin, HIGH);      //Start measuring bits, I only want high pulses
  for(int i=0;i<31;i++) {              //Parse them
    if(data[i] > bin_1) {              //is it a 1?
      data[i] = 1;
    }  else {
      if(data[i] > bin_0) {              //is it a 0?
        data[i] = 0;
       data[i] = 2;                    //Flag the data as invalid; I don't know what it is!
  for(int i=0;i<31;i++) {              //Pre-check data for errors
    if(data[i] > 1) {
      return -1;                       //Return -1 on invalid data
    for(int i=0;i<31;i++){                //monitors the bit sequence for the specified key 111100001
        if(data[i-9] == 1 && data[i-8] == 1 && data[i-7] == 1 && data[i-6] == 1 && data[i-5] == 0 && data[i-4] == 0 && data[i-3] == 0 && data[i-2] == 0 && data[i-1] == 1 ) {
            for(int j=0;j<5;j++) {        //if found the key sequence, copy the following 5 bits to to new array keysequence
                keysequence[j] = data[i+j]; //matches the both arrays over each other for copy
  int result = 0;
  int seed = 1;
  for(int i=0;i<5;i++) {              //Convert bits to integer
    if(keysequence[i] == 1) {
      result += seed;
    seed = seed * 2;
  return result;                       //Return key number
Did you ever improve on this? I can't get it to work. I get -1 every time.
Tested working.
