Good afternoon everyone.
I think formatting is OK but apologize in advance if it is not.
GOAL:
What I am trying to do is run a NEMA34 1600pul/rev stepper motor with an Arduino Uno (let’s call it Arduino B), while counting the steps taken using a primary Arduino Mega (Arduino A) .
RATIONALE:
The reason (i think) I need to use two Arduinos is because I will be running the motor at ~300-400rpm while collecting data from a load cell, storing data to an SD, and checking a few safety switches.
PROBLEM:
When I run upload the following code to both Arduinos, I want the motor to turn 2 revolutions (3200 steps) and stop for 3 seconds, and repeat. What actually happens is the motor spins for ~20-30 revolutions, and the step count that I am reading on Arduino A is not accurate.
SETUP:
Arduino A has:
pulsePin coming from the motor/Arduino B as an input to PIN 3
arduinoPin going from Arduino A PIN 8 as an OUTPUT to Arduino B PIN 2
Arduino B has:
pulPin going to the motor/Arduino A as in output from PIN 3
dirPin going to the motor as an output from PIN 4
CODE:
ARDUINO A:
// MAIN ARDUINO, ARDUINO MEGA
int arduinoPin = 8; // pin connected to secondary arduinos interrupt pin 2
int pulPinIn = 3; // Pulse pin from the stepper, as an input to count the steps
int stepCount = 0; // step counter
pinMode(arduinoPin,OUTPUT); // pin to stop the motor on the secondary arduino
pinMode(pulPinIn,INPUT); // pul pin going into the stepper motor
//potVal = analogRead(potVal);
stepCount += digitalRead(pulPinIn);
if(stepCount == 3200){ // 3200 steps should be 2 complete revolutions
digitalWrite(arduinoPin,HIGH); // change the state of the interrupt
delay(3000);
digitalWrite(arduinoPin,LOW); // change the state of the interrupt
stepCount = 0;
Serial.println(stepCount); // print the step count to determine accuracy
ARDUINO B:
// SECOND ARDUINO, ARDUINO UNO
int arduinoPin = 2; // pin connected to arduinoPin on the first arduino. interrupt pin
bool dir = 0;
int dirPin = 4; // direction pin to the stepper driver
int pulPin = 3; // pulse pin to the stepper driver
int motorSpeed = 100; // motor speed (lower is faster)
int motorRun = LOW; // initial condition to get the motor to run
pinMode(arduinoPin,INPUT); // interrupt pin, pin 8 on MAIN ARDUINO
pinMode(pulPin, OUTPUT); // to stepper motor driver
pinMode(dirPin, OUTPUT); // to stepper motor driver
attachInterrupt(digitalPinToInterrupt(arduinoPin),motorStop,CHANGE);
digitalWrite(dirPin, dir); // set direction
while(motorRun == LOW){
digitalWrite(pulPin, HIGH);
delayMicroseconds(motorSpeed);
digitalWrite(pulPin, LOW);
delayMicroseconds(motorSpeed); // rising edge to spin the motor
void motorStop(){
motorRun = !motorRun; // stop/run the motor until a change from the MAIN ARDUINO pin is seen
QUESTION: Is there anything I can do to my current setup to generate an accurate reading of the step count?
