I have very little experience with electronics and need some help. I need to control a DC linear actuator. The actuator operates at 12 VDC and draws up to 10A of current. Is there a type of Arduino controller that would work with such a motor?
Not directly you need some sort of driver to boost both the voltage and current.
That is a very large amount of current so as you are a beginner I suggest you get a ready built motor drive. You need to control its direction as well so you need a H-bridge design. You need the drive to be specified at at least 15A if the motor takes 10A.
