Using an Arduino to capture GPS Data
I am new to Arduino and having searched the forum for help have decided to ask my question here.
I need to capture GPS NMEA sentences from a GPS unit that sends a continuous stream of data every second. I see that there is a sample script provided with Arduino and I am quietly confident that I will be able to adopt it to my requirements.
My question here might seem trivial but try as I might I haven't discovered a tangible solution through my searches.
The GPS unit uses a serial connector presented as a 9 pin D Type. I would like to use the simplest connection between the two devices and have settled on the DUE model. The reason I made this decision is because it has 2 USB ports and I think by using an 'off the shelf' USB - Serial converter on the DUE's 2nd USB port I will not need to resort to wiring into the USARTs - I am not an accomplished hardware hacker!
This is where I have come to a full stop because I have not been able to discover a suitable USB to RS232 connector. There are many available but on closer inspection the choices appear to suffer from a few problems such as driver issues for one and others which do not mean much to me.
If anyone can suggest a USB (from Arduino) to RS232 D (GPS module) which I can access using standard libraries on the Arduino I will be most grateful.
Apologies if this is a simplistic question - if I do receive any answers I sincerely hope others will benefit and I will certainly post my progress here.
Many thanks.
I'd skip the USB part and go direct RS232 to TTL.
Gurgle throws this up as the first result...
and there's also details here to get you started:
I'd say that's far easier than playing with USB.
