Hello to all…
Basically I’m trying to display numeric values from a pot (A0) in the serial monitor. This is simple enough to execute but what i want to do is have those values in three separate columns (val1,val2 & val3). I want to use a second pot (A1) to select one of the columns and when I press the button it records the numeric value of pot (A0) in that column.
I figured I’ll need an array, or two? to make this work but not sure how to execute it fully. As the code stands I’m only printing the values from pot (A1). I know this isn’t correct but not sure which direction I should be going in. Any help will be appreciated
#include <MIDI.h>
int buttonPin = 2;
boolean currentState = LOW;//stroage for current button state
boolean lastState = LOW;//storage for last button state
int potValue1 = 0;
int potValue2 = 0;
int val1 = 0;
int val2 = 0;
int val3 = 0;
int myvalues[] = {val1, val2, val3};
currentState = digitalRead(buttonPin);
if (currentState == HIGH && lastState == LOW) { //if button has just been pressed
delay(10); //Button debounce
potValue1 = analogRead(A0) / 4;
potValue2 = analogRead(A1);
int index = potValue2 / 342; //returns a value between 0 and 2
//int myValue = myvalues[index];
Serial.println(index);
lastState = currentState;
You don’t really need an array as you don’t store any value, just print them
To map A1 you can
read value of A1 in a variable columnSlection
If columnSlection is between 0 and 341, remember nbTab is 0
else If columnSlection is between 342 and 682, remember nbTab is 1
else nbTab is 2
To print the right number of tabs you can use a for loop
for Index = 0 to nbTab-1 by increment of 1, print one tab
int buttonPin = 2;
int potValue2 = analogRead(A1) / 342;
int potValue1 = analogRead(A0) / 8;
if (potValue2 == 0) {
Serial.println(potValue1);
if (potValue2 == 1) {
Serial.print("\t");
if (potValue2 == 2) {
Serial.print("\t");
Serial.print("\t");
Managed to make that work with your advice. In itself it seems like a pointless objective but it was an example to help me modify another piece of code I'm working on...
you could use some else between those if to make your program go a bit faster.
Also as in all cases you print the value, Serial.println(potValue1); could be outside all the if - save some program memory
As said above printing the tabs could just be a for loop then the whole things becomes
for (byte i = 0; i< potValue2; i++) Serial.write('\t'); // write for 1 char is faster than calling print
using also meaningful variable names and constants for your pins would help readability
const byte buttonPin = 2;
const byte columnSelectionPin = A1;
const byte sensorPin = A0;
byte currentState = LOW;//stroage for current button state. LOW is not a boolean.
byte lastState = LOW;//storage for last button state
Serial.begin(115200); // no need to go slow...
pinMode(buttonPin, INPUT_PULLUP); // no need for an external pull down resistor pin -- button -- GND
if (currentState == LOW && lastState == HIGH) { //if button has just been pressed
delay(15); //poor man's button debounce
int columnSelection = analogRead(columnSelectionPin) / 342; // 342 could be define as a constant to avoid magic numbers in the code
int sensorValue = analogRead(sensorPin) / 8; // 8 could be define as a constant to avoid magic numbers in the code
for (byte i = 0; i< columnSelection; i++) Serial.write('\t'); // write for 1 char is faster than calling print
Serial.println(sensorValue);
